Greetings,
I've been gathering data. Still more to do but finally put my inverter cover back on, and removed the welding shunt I used to confirm current flow with data from the OBDII stream. That was pointless I must say....and dangerous, not recommended but now I know for in the future (it is sealed, red RTV). Had my lineman gloves on though...
There has been some speculation after my above post regarding the HV Charge Cycle/Mode and Lithium storage levels (40-60% total capacity). Some said that HV Charge is a "fast DC" charge, that it wasn't intended for static use, only while in motion. I agree that those were the intentions for the end users, however based on what I see system wise, the "unseen letter" makes sense to me. I can tell you that the behavior of the system appears to makes no preference. In fact, when used in motion, the current swings are very dramatic when regen braking is used (but I will save that for a separate thread). It also seems to be relatively efficient considering the inherent losses of a ICE-gen-storage systems, thermally and mechanically. Not going into the fuel efficiency, as a gallon of gas has about 33kWh of energy in it, little of which a gas engine releases for mechanical use....
I will start another thread for most of this charge/discharge behavior in the various modes while driving once I finish a few more tests. However, only in relation to my prior post here, as it pertains to "storage charging" this is what I found. Using HV Charge while the vehicle is parked to "top up the batteries" and blow out the dust (in the ICE), this is what happens.
Assuming the battery is below the 57% HV Charge Mode functional initiation range.
Condition tested: vehicle sitting in driveway, ICE cold as the high idle warm-up which of course only lasts a short time.
ICE warm-up runs between 1500-1800 RPM in my tests (temp outside was 75 deg), estimated HP based on fuel flow is 9 HP
ICE Idling at ~1200 RPM, estimated HP based on fuel flow approximately 4.5 HP (however I do not have a specific measure for an Atkinson cycle engine, this is based on Otto)
* this is never "free idle", like a regular car in neutral with the accessories off, as the generator is attached and always engaged. I never found a mode while not driving or stationary that the GEN was not producing some current. It gets really interesting when the "gear" is engaged (but again for another thread).
- ICE cold (1500+ RPM), HV battery at fully discharged (20% SOC/Total Capacity)
- ICE cold, HV battery at 55% SOC to HV Charge shutdown
- ICE warm (1200 RPM), at 20% SOC
- ICE warm at 55+% SOC run until HV Charge cut-out at the ~57.7% SOC. (For my car it was almost 60% before it cut off at 315.2 volts)
1) Charge current into HV Battery ~20 amps peak, average at ~18 amps or ~C/3 for rate of charge (about 6KW, or L2 rates) . This is not even close to DC fast charging or the C1 rate.
2) Almost same rate of charge as far as watts (around 5500) , however the amps decrease slightly as the pack voltage increased (with engine RPM's a constant this makes sense)
3) Charge current into HV Battery averages around 8 amps, or ~C/1.5 for a rate of charge (wattage around 2500).
4) Was surprised, there was no taper of current before cutoff. It was holding around 2200-2300 watts until it simply turned HV Charge mode off (~7 amps at 315 volts)
During all of the above, the 12volt battery was of course held at the 14.4 range (charging). So, this charges all the batteries, and runs the ICE and vehicle systems.
Interesting is that there is only about a 600-800 watt loss in ICE power output (shaft HP) to HV charge current input. I know that some of this is lost to loads other than the HV pack (which is all I was monitoring power input wise). Some of that wattage is going to the 12 volt battery and all the other vehicle systems (fans, lights, pumps, computers, etc). This is expected, however I found it amazingly low based on the torque calculations. Considering conversion and efficiency losses (thermal etc) I am pretty impressed. Again, it seems Honda was concentrating on efficiency in the system.
Again, this applies to the use of HV Charge at idle / stationary - not driving. I'll do that later, when I can go through the spreadsheets more. However, I will say that current swings exceed 150 amps charge / 250 amps discharge frequently while driving. Coasting down a big hill or mountain can result in charge rates greatly exceeding 2C if you use regen. I now have no doubt why the ICE turns on and motors to dissipate excess current. I watched the ICE (when running) in HV mode dissipate surge current (150 amps without to 35 amps with) while braking with full regen selected from moderate speeds.
*If this info has been reported before, I missed it during my searches, sorry...
Ok, killed one day of boredom due to covid, on to the next project and back to the CAN hacking.
Cheers,
Cash
