We've owned our Kia Niro for ~3 weeks now. I installed a ChargePoint 32A charger the day before we purchased it. Every day, my wife gets home, plugs it in, and the scheduled charging (on the ChargePoint app) starts at 9:30pm. It's worked without any issue.
Last night, I checked the app at 10pm and it wasn't charging. The ChargePoint lights up green when not connected, and blue when connected, and pulses when charging. It was lit blue, so it recognized it was connected to the car. However, it wasn't charging. The charging plug also wasn't locked in in the car. Tried a multitude of things to get it to charge - reset the breaker, unplugging and replugging in different ways, factory reset of the charger. Couldn't get it to charge. The app would display "Failed to start session" after hanging for a min or so.
Then used the factory charger, and it immediately locked the plug in and started charging. I assumed there was an issue with the ChargePoint.
This morning, I unplugged the factory charger from the wall. The car wouldn't unlock the plug, and the dash showed it as still charging. The car was unlocked. I ended up having to pull the cable disconnect under the hood to get it to release. At that point, the dash finally stopped showing it as charged.
Plugged in the ChargePoint, and it started charging. But, after stopping the charging through the ChargePoint app on my phone, The dash continued showing the car as being charged. Again, I had to pull the release under the hood to get the connector to release.
Since this happened with both the factory charger and the ChargePoint, I'm inclined to believe this is an issue with the car. Has anyone had a similar situation? Going to do some more troubleshooting tonight if it acts up again. The car only has 1,900 miles on it. Just trying to avoid a dealership trip.
Thanks in advance.
Thanks in advance.
