Tracey Goold
A new Kona electric and just found the charging lead in the boot. Can someone advise where to use this?
Thanks
Thanks
Judging by the "boot" clue I am guessing UK or Europe? It is a good thing to include location in your profile.A new Kona electric and just found the charging lead in the boot. Can someone advise where to use this?
Thanks
Thank you.. it's not about where the charging point is in the car, it is a charging cable in the boot but think I have sorted it now.Are you asking where to plug it in to the car? or are you referring to a Level 2 leadused in Europe. The level 2 lead is used at public Level 2 EVSE charge stations. If your asking where to plug it in on the car there is a port on the front of the car on the driver side of the car. Press in on the upper right corner about a 1/4 inch and let go. It should pop open behind the port you will find two covered plugs . Remove the top one and plug the large end of the lead into it and the other end in to the appropriate wall socket (or if its a level 2 lead in Europe the other end plugs into a level 2 EVSE) and the car will start charging. Once the charging is complete you will need to press the unlock button twice to unlock the charger so that you can remove the plug form the car. I suggest reviewing the manual for all the details on charging the car. If that not the question you were asking please clarify and I will try to respond.
