Whenever I set my charge (AC charge) to less than 100% (e.g. 80%), let it finish the charge cycle, then disconnect the charger once finished, and turn on the car, I get an alarm and this message: "not charging, current battery level is higher than set target level". However, the car says it has charged to 80%. Also, the little charging indicator light is red instead of green. Which indicates some sort of fault?
I took it in to the dealer describing the problems and they had to contact the techs back in California, but basically after two days of "working on it" they just "fixed" it by adjusting my charge setting to 100%. I'm not sure if this is something I should be concerned with as this is my first electric car.
