David Dutton
Does the Niro support routing in the apple car play map? Which app would I use?
I know that Carplay supports Apple maps, Google maps, and Waze. There might be more that I don't know about. If you use Apple maps you can control it with Siri by pushing and holding the voice button on the steering wheel for a few seconds. Using voice commands with Google maps is a bit tricky to set up but can be done using Apple shortcuts.I use Waze
I'm referring to the latest ios update. Apple maps should now be able to do route planning like a better route planner.I know that Carplay supports Apple maps, Google maps, and Waze. There might be more that I don't know about. If you use Apple maps you can control it with Siri by pushing and holding the voice button on the steering wheel for a few seconds. Using voice commands with Google maps is a bit tricky to set up but can be done using Apple shortcuts.
. . . and make money . . .Ensure reliability and build legitimacy.
