Cannot get inside
  • Thread starter Thread starter Alex800st
  • Replies Replies 10
Alex800st
All of a sudden front passenger door stopped working. Cannot open it from inside or outside, using remote or door buttons. Little thingy above inside handle moves like it should, but door can’t be unlocked.
3 month old car. Frikin honda, not geo metro.
Happened on the same day when Sirius sat radio demo subscription expired, I am sure they lock my door remotely as a revenge - I refused to subscribe.
Any ideas? Hate to kill half a day in dealership.
No luck with the physical key either?
Do you mean it cannot be opened, or cannot be unlocked? If you use any method available (remote, interior switches or manual lock roller) to unlock it, can you then open the door? If not, then the cam on the latch control cable may have somehow fallen out of the slot that lifts the spring loaded locking mechanism (the actual physical catch on the door that secures it to the loop bolted to the door frame holding it closed). This can be a DIY fix, but I would not recommend it as your car is under warranty for such a failure and should be looked at.
How dare you not pay homage to the XM Satellite Beings, you didn't at least make an offering?
Cheers,
Cash
It sounds and feels like the lock itself works, but still cannot open the door. Made a service appointment, but as I do not trust these people at all (my kid worked at the dealership, I know) I’d better try to break it myself today.
Is there an easy way to remove inside door panel with the door closed, or at least bend it so I can peak inside the door?
Physical key hole exists only on drivers door, and does exactly the same as remote or door lock buttons - locks click, but pax door still cannot be opened.
You need to use panel pry tools (plastic spades) to pry the door trim away from the frame and then pop it off. There are a lot of clips and snaps. You have to have the door open to do this. I was looking for my Crutchfield master sheet for the car and cannot find it (very annoyed about that...)
This is a video, some similar steps to installing speakers. The only screw holding the panel on is in the door handle (not latch) so you remove the trim with the window switch/door lock and then remove that screw. Honestly recommend you pay the $10 for a day on Honda Tech to get the guides you need and maybe a troubleshooting path.
https://techinfo.honda.com/rjanisis/logon.aspx
Cheers,
Cash
The simplest way to assure a car will never break (or an aircraft) is to have a mechanic/technician on board (riding) all the time. I hate Murphy...
Glad it opened! Cheers, Cash
BTW, if for some reason you do want to get Sirius/XM back, DO NOT budge for anything above $30 for 6 months or $60 a year for Select. And push enough for a free Echo Dot.
If you must get Stern, All Access is $50 for 6 months or $100 for the year.
