Can I change charge times without using Hondalink
  • Thread starter Thread starter Aaron
  • Replies Replies 7
Aaron
The Hondalink app is....at best....trash. It takes FOREVER to update charge times IF it works which is like....20-80 against for me right now. I live in San Diego so there is plenty of cell service.
Is there a way to change charge times without using Hondalink?
Yes, you can change it using the buttons on your steering wheel.
Wait what? I can? How??????
I found it in the strangest place:
It's good that the DII always tells you if the charging timer is set when you power down the Clarity.
I didn't have any earthly idea what that meant. I also couldn't figure out what the "TCU" was.
Now I know.....and knowing is.....................
FWIW, I inadvertently created a charger fault on my Siemens VersiCharge when we returned from a vacation a few days ago. The car was fully charged, and I then enabled the nightly charge schedule via HondaLink. That was successful, but I forgot that the charger cable was still connected to the car, and the fault resulted. I removed the cable and reset the charger, and there haven't been any problems since, and hopefully no damage was done, but it was troubling. In the future, I will be sure that it is disconnected if I expect to change the schedule.
