This is so easy to remove , it doesn't need any pictures.
But if you want them , they are on page 7-17 of the manual.
(1) open the glove box (the junk will fall on the floor after step 2)
(2) turn the two little knobs on the sides and remove them ( the glove box will now fall open)
(3) Behold! in behind and SUPER easy to remove is a black cover ( press the clips on the right side and gently pull open/off)
(4) remove the filter
Total time elapsed 3 minutes (no tools , flashlight or body contortions required)
Thanks Hyundai for getting this right!
I won't even describe the bugs and stuff I vacuumed out of the filter and the box itself, does a great job.
Watch out for the fan blades below the holder
(I forgot which way the air flowed and used a sheet of paper to determine that it flows down, so be sure to point the arrow on the filter that way.
The OEM part# on the filter is 97133-K4000
The measurements are 7 and 5/8 " wide by 9 and 1/2 " long by 1 and 1/8 " deep.
