If So Equipped
I cannot get the AC or heater to work during quick charging. The Clarity BEV is obviously of two minds about it, since it ramps up the fan in pathetic anticipation of the AC or heat. First noticed last month on long trip home from dealer - it was 100 degrees outside; the car was starting to heat up rapidly so I tried to turn on the AC and got - the fan. Last night it was in the 40's as I was trying to charge (took almost an hour), and I really wanted some heat since there was nowhere nearby to hang out. Our previous BEV (and PHEV) did not do this - you could run heat or AC during charging. The Clarity behavior could be dangerous if one falls asleep thinking the AC is going to kick in, and the car gets to 130 degrees. The assumption is that this is how the car was designed; the hope is that the car is defective and can be fixed.
