Rickker
I have read a lot about this both on this Forum and elsewhere, but am still not clear just what the best practice would be in my case.
My case being: A 2019 Ultimate, Canadian model with battery warmer and Winter Mode. I live in an apartment building with underground parking, where the temperature never gets below about 5 Celsius, even if it is 20 below outside. While I have used DCFC chargers in the past, I am now only using AC Level 2 charging.
So here is the question: Since Winter Mode is designed to improve DCFC performance by having the battery warmer enabled, what would be the benefit if only using AC charging? Another stated benefit of Winter Mode is to improve cold weather battery performance. Does this mean more power, more neck-snapping acceleration with Winter Mode enabled during very cold conditions? Finally, since Winter Mode reduces range, why should I use it, if I don't use Level 3 fast chargers, and don't care if there is less power for driving around, but am more concerned about getting as much range as possible. I know the subject has been discussed before, but would appreciate some comments about my specific case. Thanks.
