Ed C
Hello, I got a question.
I commute in my Kona EV daily around 100 miles. The max range of the Kona comes around 250 miles. To help preserve the battery, it is better to charge it every day but keep it between 40-80% OR to charge it every other day but run it down from 100-90% to 20-10%???
I can either do both. More cycles but keep it between 40-80% or less cycles but a larger drain between 100-90% to 20-10%. So far I chose the more cycles route, but not sure if that is the best thing. I was hoping you are more of the expert than I am in this area. Thanks!
