Any port in a storm
  • Replies Replies 0
  • Views Views 972
bwilson4web
Subscriber
A month ago, an unexpected road closure left me driving into a rest stop with "0 miles" indicated. Explaining the problem to a maintenance man, he gave me permission to put on enough charge to reach a nearby SuperCharger. But I had to park on the grass which was not optimal. So this is how to prepare to use your 110-120 VAC, EV portable charger in an emergency.
First carry a 15 A rated, long extension cord. For example:
Or better yet:
The next problem is finding an exterior outlet:
  • Tennesse Rest Stop I65 - two were found but only one was practical:
  • Alabama had rebuilt the rest stop so this was the best:
So walk around the property and look where the maintenance vehicles are parked. Always ask before plugging in and be courteous (tips are nice.)
The maximum current from a typical NEMA 5-15 outlet should only be 12 A. But sometimes, you need to derate the charge rate because of other loads on that circuit. Start at 8 A and see what voltage the car reports. Then up it to 12 A and see the voltage drop. If large, go back to 8 A. My Model 3, 250 W/mi, will typically see:
  • 8A - ~880 to 960 W/hr, about 3-4 miles charge per hour
  • 12A - ~1,320 to 1,440 W/hr, about 5 miles charger per hour
Turn off everything you can so all the charge goes into the battery. Once you have enough with a little reserve, thank them and slowly drive to the nearest charger.
Always try to have enough reserve, typically 40 mi, to the next fast DC charger. Then drive checking the indicated range and miles to charger:
  • +40 miles - keep up with traffic
  • ~30 miles - become the slow poke, follow moving vans
  • ~20 miles - become the *sshole and use the minimum speed with flashing emergency lights
  • ~10 miles - find a safe place for the tow truck to pick you up
