So, as the Canadians are so nice that we are getting gouged without complaining, the prices of L2 chargers are almost double the prices in US... I was trying to find something reasonably priced that would qualify for the rebate, and the only one I found was the AeroVironment’s 32-amp EVSE-RS sold by GM dealers for less than $600. It doesn’t seem to be sold pretty much anywhere else, which I think is due to the fact that AV sold their car charger business to some company Webasto, which seem to have discontinued these models. Does anyone have experience with it and the Clarity?
This model is pretty basic and doesn’t have option to set to amps (basically fixed at 32), but I think it will still work ok with Clarity (which takes 30amps based on what I read here, correct)?
Also, any problems installing it on the vinyl siding? If The electrician passes the wire from the back, would it affect the weatherproofing given the bracket wouldn’t be on flat surface? They also give the option to pass the wire through the side, but I am not sure if it is meant for indoor installs only.
