As he mentions, you never really know for certain what the min/max is as far as capacity. Oh, you know that, for instance that your battery "rated" at n kW, and you would certainly know when you hit zero (but how often does that happen in a Tesla unless you plan to call the flatbed). So even at best it's all a series of estimates. I am with you on not really caring about the day-to-day fluctuations in range. I, too, just want to know where I'll be on EV range 5 years from now when I see I have a "full" battery. I take all the numbers that flash on the dash as estimates. And it's weird, because a few times I've had 45 EV miles of range after a "full charge", and other times I've had less. I have also NEVER been able to move 17 kW into the battery - and that's from a supposed empty state (as in zero miles on the EV range). If the zero miles EV range is true, then 2kW must be held in reserve - but not accounted for in the EV range estimate. When I look at my history since I've had the car, I have one charge of 15.22kW, one charge of 15.01 kW, one of 14.85kW. In each of those cases, I had 0 miles of EV range showing. So I maybe I can use the average of those 3 "fill ups" as an index of sorts. There are just too many variables to try and make a meaningful statement about EV range degradation. Season/temps, load, mode, etc. All work together to eat away at range.
