For powering aftermarket add-ons, it would be nice to have access to switched power (ACC, or accessory power) so the devices can’t drain the 12V battery when car is off. (Honda calls these circuits ACC so I am going to use that term even though they also use ACC for Adaptive Cruise Control.)
So far, I haven’t seen a good solution for hardwiring. Of course, the easiest is to plug into the accessory power outlets with an adapter, but sometimes that won’t suit.
I found a pretty easy way to tap (hardwired) into ACC (switched) circuits. It is not hard; if I was to do again, I’d guess 10-15 min. It took a lot of figuring out, so wanted to share.
This is the first of 3 posts (overview). The second post describes the existing ACC circuits, and gives the diagrams. Maybe someone will use them to come up with an even better option. The third is my solution.
Note that this solution taps into the same circuit as the front console accessory socket circuit, and with 18ga wires, so would max out at about 10A/120W. My needs were pretty modest: powering a Thinkware dashcam that had both Parking and On modes, and a BSS1-LPB rear cross-traffic/blind spot sensor. If you need more power (for your big amplifier or hair dryer or whatever) there is a suggestion at the very end.
Post 2 to follow....
