SteveEngineer
The Mustang Mach-E is a totally awesome EV as it stands, but there are a few things that might be done to make it even better in the near future. I probably missed a few obvious suggestions myself. I’m pretty sure that Ford monitors this website — so maybe a few of the following improvements might actually make it into future MME builds.
Standard:
Higher voltage charging ability (e.g. 800 volts) for faster charging with the highest power DC chargers.
Improved HVB cooling for longer sustained DC charging maximum rate (than the current 0.1 hour or less).
Ability to limit the maximum L2 charging rate for use with lower current 230 VAC circuits while traveling with the Mobile EVSE. An OTA software upgrade perhaps?
Improved “Moose Avoidance” handling — minimize vehicle oversteer during such a maneuver.
Eliminate side view mirrors for better aerodynamics and reduced wind noise, display images on the driver’s video console instead.
Available Options:
Fog/cornering lights for all trims (and not just on the GT and GT Performance).
A choice of something besides a black interior for the CA Route 1 trim. Grey? Tan?
Improved headlights to upgrade Select and CA Route 1 trims to meet the highest safety rating for those of us who drive a lot after dark.
Retractable sunshade for models having glass roofs for those of us living in hot climates.
Heat pump to replace/supplement resistance heater for passenger compartment for improved cold weather range.
Bidirectional L2 charging ability to provide household emergency backup power and the ability to store off-peak energy for later use for those of us forced to use time-of-use utility pricing..
Standard:
Available Options:
