Not enough description to make any diagnosis/ change an alternator belt/ oil the motor / wash a car / or some rodents under a hood making squeak sound ! You are under warranty don’t worry at this point enjoy SE drive harder !My Mini SE makes like a 2-3 second squeek sometimes when "starting up." Is anyone else experiencing that? Any idea what it might be? Should I be concerned? (It's in warranty, so all good, just wondering what I'm dealing with)
Ya, I figured out it only does it's little squeek when I have the heater or air conditioning on. I'm wondering if it uses a belt on the heater/air conditioner, and that's what's doing a mini squeek.Not enough description to make any diagnosis/ change an alternator belt/ oil the motor / wash a car / or some rodents under a hood making squeak sound ! You are under warranty don’t worry at this point enjoy SE drive harder !
No belts on EVsYa, I figured out it only does it's little squeek when I have the heater or air conditioning on. I'm wondering if it uses a belt on the heater/air conditioner, and that's what's doing a mini squeek.
I knew that was the case in general. I was really hoping that was the case in this instance too. Nice, I wonder why the cabin heating/cooling system would squeak.No belts on EVs
