A Few questions
  • Thread starter Thread starter GPM432
  • Replies Replies 1
GPM432
There seems to be no info on changing a tire on the Kona EV.. does any one know if there is a jacking point on all four tires I see the frame is metal but I don't know if you can use a scissor Jack there.
Can you turn off the beeping sound of the lane assist or do I just need to shut it completely off. You can turn the beeping sound on the Blind spot mirror.
That's it for now the car is fabulous.
The jack positions are marked on the chassis, I had the service tecks hoist it before delivery and noted the marked positions on the frame.Small marks about 3"wide 1 /3 and 2/3 locations.
The jack to lift at one of these 4 positions would have to rated for half the weight of the car as it would probably lift the entire side of the vehicle.
If the intent is to replace a tire (temp) due to an emergency situation I agree and a suitable spare:
https://www.wheel-size.com/size/hyundai/kona/2019/
depends on offset etc which I am also checking ( note 67.1 mm center bore )
Would like an emergency spare to fit under rear area
As far as beeping LKA i'm not sure
  • Like
Reactions: mho
