Hello again, and let me start by saying thanks for the assistance in my other thread earlier today. My wife and I have a few other questions that have come up from reading around through the forum. I am only making a new thread here in the interest of grouping the answers that matter to us together, and more importantly to make sure that the answers are current and not reflective of issues that Honda has already dealt with. For background, we are looking at higher-VIN 2018 leftover Touring models; mainly curious about life with an updated and service-bulletin-ed Clarity - what problems persist versus which were teething issues at release and has been de-bugged since.
1) HondaLink App and preconditioning. A lot of discussion early on about the app not working, or not working properly. Has that mostly been taken care of? Is it pretty stable now (would be using on current gen Apple phones/IOS)?
2) Preconditioning through the App... What all can be controlled. Is the control just on/off, and the system operates as needed based off the temperature chart/parameters I've seen elsewhere? And does it matter what the last setting you were using in the car while driving was? Are those who use it finding it to work well?
2a) Is it possible through the app to precondition when away from home when battery is low (lets say you're roadtripping and have used most of the tractive battery charge)? Is there any way to force ICE run to charge the battery, and thus let the climate control work, or is it something you have to specifically plan for if you want to be able to do it? (i.e. make sure you arrive at the amusement park, or festival, or whatever with at least x% battery left)
3) Does preconditioning through the app still mess with XM or other infotainment screen stuff.
4) We will be using just L1 charging at home. Does that mean we can't precondition in the garage? Or is it possible to shut off charging and then precondition, all from the app?
5) The split driver side mirror... It isn't the same as BSD, but does it seem a helpful improvement visibility-wise over a normal side mirror? (That is one thing we didn't get to pay attention to in our test drive, and there are no cars near us to go try again. I feel like even rolling into the lot I knew about as much about the thing as the sales guy did, but after coming home and diving into even more reading there are so many other things I wish I had known to look for, try, check, etc. C'est la vie, I suppose.)
6) How many routine driving activities require interaction with the touchscreen, in your actual experience? I have seen that expressed as a concern, but again, I didn't thoroughly play with lots of things during my tester.
7) Anyone who is familiar with both cars.... Are the preconditioning choices/options of the Clarity the same as (or less, or more) than with an Accord Hybrid? If different, what things can you do with one that you can't with the other?
*edit* 8) Is there any chance that, since the touchscreen/infotainment/nav arrangement is a slightly older vintage, that Honda will cease properly supporting it (parts, updates (idk if that is even a thing for these), etc) within the timeframe of, say, a ten or slighly more year ownership? */edit*
Thanks so much in advance for any thoughts and input you may have. I am in a few similar communities where I get to be on the other side of questions like this sometimes. I know it can be frustrating to be seemingly giving the same info so many times, so I really appreciate whatever help you can give me as I try to sift through what is old vs what is current, what is real vs what is user error, what is a one-off issue versus what is a frequent one, etc.
Thanks,
Grant.
Thanks,
Grant.
