I've reserved the 1st edition and began researching the available specs. I am suspicious of the 250 mile range. The EPA rates efficiency at 35kWh per 100 miles. At this efficiency, 250 miles requires 82kWh of battery. VW only allows normal use of 77 kWh. This means for the EPA test they had to consume the full 82 kWh. Will this be available to all consumers or did VW hack their battery controls for the EPA test?
