Which home charger will you choose for your new Kona or Niro
Discussion in 'Hyundai Kona Electric' started by EnerG, Dec 1, 2018.
  1. I am very impressed with your DIY holster. I notice now that Morec includes a holster, but not when I ordered mine.
  3. Bugblndr
    Bugblndr Member
    I just downloaded a design by someone else and printed it. https://www.thingiverse.com/thing:2446369
    I will redesign if need be down the road. Won't know till I get my car and start regularly using the charger.
  4. Bugblndr
    Bugblndr Member
    Thanks, I can't take credit for the holster design, only the production! The pictures on Amazon show a holster but when I received mine 2 weeks ago, I don't recall seeing one in the box. No big deal, I wasn't going to use it anyways as I wanted an integrated cable holder.
  5. Bugblndr
    Bugblndr Member
    Last weekend was installing a charger at home. This week I installed one at the family cottage. I went with a 240V 16A Level 2 Duosida for this install for two reasons:
    • The 120V EVSE included with the car would take too long to charge to return home after a 1 or 2 night stay.
    • A 32A EVSE would require a major rewire.
    Total cost was $250 + HST including the breaker, outlet, box, faceplate and EVSE. Once again I printed my own holster.
    XtsKonaTrooper likes this.
  6. Spotlight Research
    Spotlight Research New Member
    Hello all,
    This is not related to the question at hand, but is related to the topic of Hyundai Kona EV models. I work at a market research company and we are always hosting automotive research studies local to the US. We are currently hosting a research event in the Los Angeles, CA area looking for Kona EV owners. All of your time spent is compensated for and the best part is you give your true thoughts and opinions on your vehicle and vehicles like yours. This event is taking place on Wednesday the 21st of August and compensating $240 for 3 hours of your time. There is an additional portion to the study that pays an additional $275 for a total of $515. The compensation is provided in a check/cash form. I assure this is not a sales tactic. If you are interested, please call us at (818) 626-5588.
    Thank you
    Spotlight Team
  8. 2P 20 A breaker and #12 wire should handle it. Is that a square D box?
  9. Bugblndr
    Bugblndr Member
    12/2 wire and a 20A double pole breaker. Regular box with a NEMA 6-20 outlet.
  10. Ray C
    Ray C New Member
    What is wrong with installing a NEMA 6-50 receptacle. My dealer says they will supply a level 2 charge cord. Still waiting for my Kona, 6 month wait time! Should be here in Dec.
  11. Bugblndr
    Bugblndr Member
    Pretty much all Level 2 32A EVSEs I've seen use a NEMA 14-50 outlet. Make sure you wire for what you're getting.
  13. Is there such a thing as an EVSE to charge 30A at 120V using and RV campsite outlet (TT-30)? And hopefully a cheap one... And not looking for a multi amp/voltage EVSE like the Zencar (which is expensive).
  14. The Chargepoint charger I had installed specifically required 6-50 wiring/receptacle.
    CHARGEPOINT HOME 32 AMP, 18' CORD, PLUG STATION (CPH25-L18-P)
    Model CPH25-L18-P
    18-foot cord
    Suitable for indoor installation only, certified electrician required
    J-1772 Connector, works with all electric vehicles on the road
    Manufacturer: ChargePoint, California, USA
    Output: 32 Amp, 7.6 KW
    Charge Rate: 40 km per hour
    Power Requirements: Requires Dedicated 240 V 40 Amp
    Charging level type: Level 2 Charger
    Charging cable: 18 Foot
    Regulatory compliance: cUL
    Wiring: NEMA 6-50
    Mounting type: Wall Mounted
    Plug type: J1772 – universal to all EV’s
    Application: Indoor
    Operating temperatures: -30 to +50 C
    Smart Charger: Yes, WiFi Smart Charger, Reporting, Smart Phone App, energy metering, notifications
  15. Ray C
    Ray C New Member
    Thanks for the info. I will install the 14-50
  16. Why not just run the #8 cable and terminate it when your EVSE arrives?
    Bugblndr likes this.
  17. Ray C
    Ray C New Member
    Good idea. AmI wrong but Kona has onboard 7.2kW charger. Why can't I wire 240V directly to Kona without a Charge point or other device. I have 240V 50A in the garage!
  18. Esprit1st likes this.
  19. Ray C
    Ray C New Member
    Thanks, article informative.
  20. DelRider
    DelRider Member
    I went with a plugged ChargePoint 50A/240 L2. I had the electrician put a NEMA 6-50 plug in the garage. Following advice posted elsewhere around these parts, I had him run a full 4-wire cable and capped off the unused wire, so going 14-50 in the future will be a non-issue. On the charger itself, very slick and clean. Install was a breeze and it hooked right up to the wifi. The state kicked in 50% of the charger cost and the $50 ChargePoint network credit are nice bonuses; would buy again.
    NP27 and electriceddy like this.
  21. robxb
    robxb Active Member
    How has your charging experience been with the morec so far? Thinking of getting this once I get my Kona
  22. robxb
    robxb Active Member
    Hi R P, can you link me to that other post? Can't seem to find it.. I would like to know why you decided against Charge Point, as I am also considering the Morec
  23. robxb
    robxb Active Member
    Sorry, one more question. Can you possibly take a picture of the label that shows where it says TUV? Does it say TÜV SÜD, or just TUV without any special characters? Just want to be 100% sure that there isn't some loophole where "TUV" is some other thing, rather than the actual "TÜV SÜD". I keep seeing things around the web (mostly on Amazon) saying insurance doesn't cover if it's just TUV, even though I'm seeing elsewhere that TUV meets the Canadian Electrical Code is SCC accredited (though not CSA, as it's a "competitor" or whatever)
