I wrapped the wire several times around the base of the coil, and taped the end of it onto the top of the coil. It seems to work well. The engine has run a total of 0.6 hours since installation.
Thanks. I took a quick look without totally removing the cover. Looks like the coil is directly attached to the spark plug (no HV wire). Is that correct?
Rob, many, many thanks for the great info on this and especially where to wrap the inductive wire. Using your experience, I was able to install an hour meter. I found a pretty good spot to mount it that requires no modifications and doesn’t interfere with removal of top cover for servicing. I made a new thread on he installation. Your info made it easy. Thanks again
