What is this icon on dashboard?
Discussion in 'Clarity' started by Alex0913, Jan 13, 2019.
  1. Alex0913
    Alex0913 Member
    0FF0ACC0-690F-45C4-8C8D-4BD4B0C9324D.jpeg I don’t remember seeing it on, does anyone know? Do you have it on? Thanks in advance!
  2. amy2421
    amy2421 Active Member Subscriber
    I think that is a "Check Engine" icon. It is not "on" on my Clarity.
  3. Alex0913
    Alex0913 Member
    Thanks for the reply! This happened after getting the multiple warning lights after the charging station stopped charging the car for some reason. All of those went away on their own, but that one remained, so weird.
  4. Robert_Alabama
    Robert_Alabama Active Member
    Yes, that is normal behavior after the charging error. It should reset (light will go out) after a day or two of driving.
  5. Walt R
    Walt R Member
    Yes, this is the way most cars work now. The "check engine" or "MIL" (Malfunction Indicator Light) indicates that there are diagnostic codes that have been recorded. As it is yellow it is only a warning, not a problem. It generally resets after 24 hours or so.
  6. amy2421
    All these reports of warning lights after using a public charger have me very leery of charging anywhere except at home! I have not used a public charger yet.
  7. RickSE
    RickSE Active Member
    I used to get these warnings 2x per week when I used my work chargers. After the 097 software fix the car charges almost all the time without any issues (Clarity is a bit more sensitive then other EVs at my work) and I have not seen those warnings on the dashboard at all.
    LegoZ likes this.
  8. petteyg359
    petteyg359 Active Member Subscriber
    Sounds like you didn't bother to get the software updates. Take the car in and get the software updates. "Multiple warning lights" was fixed several months ago.
  9. Alex0913
    Alex0913 Member
    I hadn’t had that issue happening after charging it a public station so I went with the “if ain’t broke.....” but now I will take it in for sure, thanks everyone for your input.
  10. petteyg359
    Yet, it clearly is "broke"...
  11. Alex0913
    Alex0913 Member
    Thanks again
  12. Aaron
    Aaron Member
    I got that light a few times using my work chargers. If you have an OBDII you can clear that yourself.
    My work chargers never charge back to full so I have just stopped using them. Now I just charge at home. It's sad because it's 60 miles round trip for me to work which means I spend at least some mileage a day in HV mode.
  13. petteyg359
    Just remember, you're still four times better than the idiots commuting in their F250 trucks on an mpg scale of betterness
  14. Aaron
    Aaron Member
    Hahaha!! I USED TO BE THAT GUY! I have a 2006 Nissan Titan and I was spending 400 dollars a month on gas. Hence.....The Clarity....which I love.
    In all fairness though....whenever someone needs something moved who do they call....the Clarity owner or the Titan owner?
  15. petteyg359
    True. I'm still hanging on to a 2001 CR-V for the occasional IKEA trip.
  16. su_A_ve
    su_A_ve Active Member
    My work chargers would give me issues which would eventually result in the charging system problem error and check engine light. No issues after the software fix. So if you haven't gotten it yet, get the update and try again.
  17. Aaron
    Aaron Member
    I took my Clarity to the dealer who said I have all the software fixes (this was in November) but I am still having the issue.
