What is the "final" fix for the battery fire recall?
Discussion in 'Hyundai Kona Electric' started by Telek, Jan 27, 2021.
  1. FloridaSun
    FloridaSun Well-Known Member
    I'd think that it applies to both. DC fast charging slows down to close to Level 2 speeds towards the end of the charge.
    Lars likes this.
  3. Just saw this article today. Looks like they're doing one of the most expensive recalls ever.
    https://www.caranddriver.com/news/a34317051/hyundai-kona-electric-recalled-korea/
  4. feedtaletwo
    feedtaletwo New Member
  5. SeanH
    SeanH Active Member
    My background: Electrical Engineer specializing is robotics (especially mobile, autonomous).
    I was completely gobsmacked... beyond flabbergasted when I read that LG's response was that although they had supplied the batteries, the problem was that Hyundai "incorrectly implemented the BMS".
    W.T.F.
    How the hell did someone think it was the right idea for one company to create a battery with 230,400,000 Joules of energy, and then have another company write the management software that is supposed to correctly charge and balance the battery!?!?
    That takes "whoops, I misread the datasheet" to a whole new level. The battery should come with a BMS. Period. End of story.
    (and, looking at GM, it seems like Hyundai wasn't the only company that "incorrectly" implemented the BMS...)
  6. One would assume that would have been the whole purpose of the H L Green Power venture and should have been dealt with at that level:
    https://www.insideevsforum.com/community/index.php?threads/kona-ev-500-hyundai-company-is-considering-a-plan-to-compensate-customers.9699/#post-111351
    but apparently this was not the case.
    A very expensive lesson indeed.
    It would make sense Hyundai should not supply/program the BMS for Ionic 5 (E-GMP platform) using the SK and CATL cells exclusively, but work more closely with these companies to co-ordinate a more positive outcome.;)
    lars2885 and Lars like this.
  8. One would think that both Hyundai and LG Chem learned an expensive lesson both, in terms of money and a big hit on their reputation.
    On a positive note, the last batch of my one time use bolts are at the dealer being used to secure the battery. Based on my past experiences "I am cautiously optimistic" that I can pick the car up today. :)
    BC-Doc likes this.
  9. If my memory serves me right, GM has 'subcontracted' the design of the entire electric component of the Bolt to LG Chem. They were even called out on it as it is NOT an 'American car' - as GM promoted the Bolt.
  10. doggyworld
    doggyworld Active Member
    I'm a bit worried that since they don't truly know the cause of the fires, they're really just guessing and replacing a bunch of batteries while guessing I think is a bad idea. If they replace all the batteries and fires start again, what happens then?
  11. Kevin Nguyen
    Kevin Nguyen Member
    I think somewhere they said the battery and the BMS need to be replaced at the same time. HYUNDAI misapplied the charging logic to the battery that cause the battery fail over time.
  13. DAS14
    DAS14 New Member
    Should we assume that individuals who had their HV battery replaced that these batteries and software are correct now or does the software still need debugging and another battery that is yet to be tested and deployed?
  14. H L Green Power appears to be just an assembly operation. Mobis most likely designed and build the BMS and there's nothing untoward about that, they design all the major electronics assemblies. The LG Chem E63 cell datasheet, which we have a copy of (linked in the relevant thread), dictates the charging specifications on page 6. Past that it's a matter of completing normal design verification and validation processes.
    Clearly there have been errors but we don't have enough information yet to pinpoint who is responsible. Most importantly to us, Hyundai, as the systems integrator and end product manufacturer, appears to be backing their product at significant cost to themselves.
    From the Mobis website:
    electriceddy, lars2885 and Lars like this.
  15. TRSmith
    TRSmith Member
    Sorry if it's somewhere in the thread, but what's the cutoff battery manufacture date for the recall?
    I had to get recall 196, so I assume I’m subject to this too, but wanted to check anyway since I found my battery label.
  16. All good points! We are getting into fault finding mode here and we clearly not equipped to do that regardless how much specs etc. we dig up.
    As for myself, after four months, I got "Sparky" back today. All recalls to date and proper bolts :mad: included.
    I drove home with a big smile on my face. :):):):)
    BC-Doc, R P and electriceddy like this.
  17. Sept 29/2019 thru March 13/2020:
    https://en.yna.co.kr/view/AEN20201008006400320?input=2106m
  18. TRSmith
    TRSmith Member
  19. Now you will be able to read the label on the new pack and post it please?;)
    Edit...unless I missed that somewhere
  20. Both the USA and Canada have links to see any Hyundai recalls, here is the Canadian one:
    https://recall.hyundaicanada.com/
    and USA:
    https://autoservice.hyundaiusa.com/campaignhome
    You can also check Transport Canada Website and NHTSA in the States
    Take it with a grain of salt, as they are not updated regularly, best to check with the dealer;)
  21. I think you nailed it exactly with the verification and validation process, this is likely the primary point where mutual co-ordination between the supplier of the cells, the implementation of the BMS and final assembly manufacturer is most important.
    KiwiME likes this.
  22. FloridaSun
  23. I already posted it but here it goes. Manufacturing date is 2020-10-07. For reference; my car "was grounded" on 2020-10-23.
