Top Wishes (to Honda) - Persistent Modes (or persistent HV), and Quieter Gas Only
Discussion in 'Clarity' started by Dan Albrich, Nov 21, 2018.
  1. MNSteve
    MNSteve Well-Known Member
    Allow me to share the perspective of us flatlanders on this issue.
    I had a friend who, when the phone companies were decommissioning the microwave links, bought some of their towers. He started a business renting antenna space for companies that needed radio communications. Our conversation went something like this:
    Him: "I've got towers on all the mountains around here."
    Me: "Mountains?"
    Him: "Yeah, like this one is 300 feet above the average terrain elevation."
    300 feet constitutes a mountain around here.
    But I am very interested in these quirks of driving a PHEV. It's a whole new world to explore. Thanks to all of you for sharing.
    MPower and insightman like this.
  3. RickSE
    RickSE Active Member
    Now that winter is reducing my EV mileage I started looking through these (very helpful) threads on the best way to drive the car. I try to stay in EV mode in the city and on the congested highway part of my commute. When traffic clears on the highway the HV goes on because at 23¢ per kWh gas is cheaper then electric. I think that because the car is so quiet in EV mode when the engine goes on I notice the noise more then I would in any gas car. I do wish there was some way to slow the engine because it just seems that it is working much harder then it needs to in maintaining highway speed - or it’s all in my head because the EV is so quiet and the HV might just be as loud as any gas car and I’m not used to it anymore. A tachometer might be interesting in the Clarity to show what that engine is really doing.
    Randy Stegbauer and 228ra like this.
  4. MNSteve
    My thoughts exactly. I find the sound of the engine very annoying in stop-and-go driving, but I am not sure whether that's because it is loud or that I am spoiled by how smooth and quiet things are on EV.
    Ceetee likes this.
  5. David Towle
    David Towle Well-Known Member
    Its quieter in gear mode on the highway. I am finding I can get it to stay in gear mode 90% of the time if I drive without using the cruise control. When I use the cruise it varies speed too much and is in gear mode only about 10% of the time.
  6. ab13
    ab13 Active Member
    RickSE and David Towle like this.
  8. David Towle
    Great info, thanks. Key points for me are maximum EV efficiency is at about 28 mph, and the engine is turning about 2500 rpm at 70 mph in gear mode. Confirms the best way to drive the car is EV off the highway, HV on the highway, unless you are lucky enough to have super cheap or free (work) electric rates.
  9. RickSE
    That’s a great article and very much supports using HV at highway speeds. Also explains why the engine sounds so loud when exiting the highway. It’s the perfect storm of speeds dropping down from >60 through 50 & 40 - which looks like the speeds where the engine runs the fastest. I’m one of the lucky ones that gets free charging at work with a round trip commute of 35 miles so I almost never use the engine. Three months and 3300 miles using 9 gallons of gas.
  10. insightman
    This is great! The 2013 Accord Hybrid-specific paper "Efficiency Enhancement of a New Two-Motor Hybrid System" by Naritomo Higuchi and Hiroo Shimada was a good discussion of Honda's i-MMD system, but this one actually discusses the Clarity PHEV. Can't wait to see the full paper. Thank you very much.
  11. Dan Albrich
    Dan Albrich Well-Known Member
    One more comment. My buddy has Prius Prime. His car is designed to automatically switch to HV mode and preserve electric charge once it hits a certain level. He never gets high RPM sound. But he also *cannot* deplete the battery-- it simply doesn't allow it. He can, on the other hand select a mode that uses more gas to preserve or build electric charge -- i.e. like our long press HV.
    But yes, if our car had a mode (persistent) that would say flip to HV mode automatically when battery is at 30% or less, that would be fine with me. Also, I would want this to be an option, and not set for everyone. But it would allow folks like me to drive and more less forget about any button presses and preserve a quiet ride.
    Finally, I suspect my battery may of been damaged by sitting for months with no charge -- this because even with little heater use my estimated range is lower than others report. Be that as it may, my 'concern' over hitting angry bees sound too much may become all of our concern as your battery ages.
    -Dan
    PS: And I hope I'm wrong about the battery and how it will handle as it ages. I'd prefer it to be just me, or I'm more sensitive to the sound than others. I'm glad for those who have never heard the angry bees, and may it stay for you.
    Ceetee likes this.
  13. MNSteve
    Definitely an option, set with all the other options. I rather think that Honda designers felt that there were already too many options and were afraid that the driver population would be overwhelmed. I don't think they realize that we can simply take the default for the options we don't care about, and people who care about none of them can take all the defaults.
    Personally, I would like to see an option to shift to HV after some period of highway driving, and back to EV when no longer at speed. I dislike remaining in HV mode as I drive through small towns, so I generally drop out of HV until I get established back on the highway. I'd like it if the car did that for me.
    Ceetee likes this.
  14. Dan Albrich
    MNSteve- I understand what you are asking. It prompts another question from me (i.e. maybe my experience really is abnormal)--does your car ever increase electric range, even a little bit, in HV mode? I don't mean long-press.
    The reason I ask is my car loses electric charge as I go no matter what I do. Even if I engage HV when I get on the freeway, and even if I'm on a flat freeway, my electric charge slowly goes down. And under no condition but actual charging or long-press-hv do I get a charge.
    -Dan
  15. KentuckyKen
    Dan, the only way to know the health of your battery is to have the dealer measure the Battery Capacity Signal with their HDS. It was supposed to be done at the PDI. It should read close to 55 Ah when new. Warranty replacement is at 36.6 Ah.
    Since I bought mine in Feb and the new PDI came out in March, it was not done for me. My dealer ran it for me when they did the first update.
    Ken
  16. David Towle
    When someone obtains the full SAE paper, please post it here as a new thread under "Clarity SAE Paper" or such so that we can't miss it in the sea of threads. Thank you.
  17. I think mine has.
    Having mountains around, I tend to start on EV and go to HV at some predetermined point, such as 10 EV miles remaining, then hit HV. The EV miles remaining then hovers around 10 miles, but mostly on the low side. But pretty sure on downhills I’ve seen it go to back to 10+ for a while.
    I’ll check for it tomorrow, when I have a longer mountain drive planned.
  18. MNSteve
    Mine went from 17 to 16 then back to 17 the other day, in HV mode. It was obviously hovering on the boundary, dropped, then it did not take much increase in charge to make it hop back. So, yes, I have seen it increase while in HV not-charge mode. I'm a flatlander, so no long hills to drive down while harvesting regen.
    One of the questions I have is the scale on the power meter for the area marked "Charge". I sincerely hope that it's not the same as the big area that measures power used, since there's only a tiny area that measures charge when compared to the area that measures use. Given that we don't know the scale, it's not possible to understand how much energy we're actually capturing by using regenerative braking. My suspicion is that it's mostly a feel-good feature and makes no significant difference in EV range unless you're descending a long downhill.
  19. Dan Albrich
    Thanks KentuckKen. So my buddy at work liked the car. Bought the same one (different color) about a month or so after me, from our same Eugene dealer. I warned him about pontential battery issue since the cars may of been delivered similar timing-- don't actually know. He asked anout the HDS battery test. They strongly refused to show it. They claimed all you need to know is on the dash display and refused to even acknowledge such a test exists. He also checked with nearest dealer in Corvallis who declined to offer him any pricing out of desire to "not compete" with the dealer here in Eugene.
    Anyway, it's likely I need drive more than 100 miles to find any dealer willing to do the test for me, and I'll likely have to pay for it. So I'm willing but doesn't seem as easy as asking...
    -Dan
  20. KentuckyKen
    The battery test was supposed to be done at the PDI per Sevice Bulletin 17-093. I have attached a copy. I showed it to my dealer and they ran the test for me since it had not been done.
    Hope this helps.
  21. Thomas Mitchell
    Thomas Mitchell Active Member
    People read the owner’s manual?
  22. Thomas Mitchell
    The cars computer does not let the battery reach”empty”. That’s why you always see 2 bars remaining on the gauge. At that level, there is enough charge to support continued HV driving. Unless something happened to your car, your battery should be fine. EV range estimation varies greatly between users depending on climate and driving habits, apparently. I’d guess your dealer can test the battery for faults if it’s a concern.
  23. Thomas Mitchell
    Your cars battery was damaged during shipping/delivery? Won’t Honda warranty that?
