Slight Battery Drain
Discussion in 'Cooper SE' started by Stephen Graff, Apr 1, 2024.
  1. Stephen Graff
    Stephen Graff New Member
    I have a 2021 mini cooper se. I left it parked in front of my house for 3 days and drove our other car. When we returned from vacation, the SE battery had lost 1% of its charge. It had been raining pretty heavily. Not sure if unlocking and starting car could have drawn slightly from battery. Is this something of concern?
  2. Puppethead
    Puppethead Well-Known Member
    I've left my SE parked for over a week (in a garage) with no battery drain. If it was cold/hot enough perhaps your 1% was used for battery conditioning, or perhaps you have an automatic climatization departure time enabled?
  3. Stephen Graff
    Thanks for responding. Temps here are in upper 40s. I don't use any of the scheduling options, so I don't think it could be that.
  4. insightman
    A 1% loss shouldn't be of any concern. It is possible that your battery was sitting just above the 1% boundary when you parked. Measuring the state-of-charge in a battery is more complicated than determining the amount of gas in a tank. Some on this forum have reported occassionally seeing 99% after charging is halted.
    Perhaps if you had parked 25 yards further down the street, the state-of-charge would have been 1% lower when you got out of your MINI and remained at that level until you returned from vacation.
    carrrl, SameGuy and Puppethead like this.
  5. MrSnrub
    MrSnrub Well-Known Member
    Zero concern. Ive left my car for 13 days once and lost 2% according to the SOC. All EVs have some drain sitting there.
  6. teslarati97
    teslarati97 Well-Known Member
    Most of the vampire drain from EVs are from the 24/7 security cameras, proximity sensors, and telematic services. Overall I'd rate the SE high voltage battery drain as no concern.
    I haven't played around with the hidden service menu (hold trip reset for 10 seconds), but I think you can see the state of battery health just like the i3 does.
  7. CuriousGeorge
    insightman and SameGuy like this.
