Service Bulletins
Discussion in 'Clarity' started by leosgarza, Oct 4, 2018.
  1. thecompdude
    thecompdude Member
    The sales person just sent me a PDF with details for my VIN.
    He is a pain to deal with. I think I will worry about this after I take delivery and then deal directly with the service department!
  3. MNSteve
    MNSteve Well-Known Member
    Which will be a pain to deal with.
    I would feel a lot better about this if it used terminology like "No items apply for this vehicle" rather than "no information is available for this vehicle." I know I am being picky, but there is a difference.
    And I would not expect 18-097 to appear here. It seems to be in a category all its own in terms of appearing on lists.
    My personal advice would be to go with the flow and not push it at this point. I don't have any of the SBs installed, and I have not decided whether to request that they install them when I take the car in for maintenance. Frankly, since I am not having any problems, I believe that the probability of an untrained technician breaking something trying to install a software update is greater than the issue that is being fixed suddenly coming to life and causing me a problem. If it ain't broke . . .
    On the other hand, if you have problems with charging, then you have motivation and justification to request 18-097. I haven't, and I haven't.
  4. thecompdude
    thecompdude Member
    Agreed. I will do the same. See if I have an issue, and then get the patch applied if needed.
    Now that I know the patches available, I think I can co-relate the problem to the solution. And only get the necessary fixes.
    MNSteve likes this.
  5. Texas22Step
    Texas22Step Well-Known Member
    Remember, safety recalls are made by a manufacturer under the regulations of the National Highway Traffic Safety Administration (NHTSA) and are listed by VIN via either the Honda web site or by the NHTSA at https://www.nhtsa.gov/recalls. I am guessing that your dealer sent you a clean bill of health for safety recalls, not for non-safety, non-government mandated OEM issues (like Honda Service Bulletins), which can also be listed by VIN (or simply by "all" VINs of a particular year/model. The safety recalls and the Honda SB's are two different animals, so make sure your dealer is offering you the SB list from i-HDS (a Honda internal network) and not the US safety recalls that you can check online yourself at the NHTSA web link above.
  6. 2002
    2002 Well-Known Member
    Depending on the manufacturing date which you can see in the driver door jamb. My 2018 was built in November so I am guessing it probably has the SB's from October. But that depends on when and where they would be updated. If you have been to a car assembly plant you can see that the cars are put together pretty quickly as they roll down the assembly line. So the updates would have had to have already been applied to the ECU or whatever at the sub-assembly manufacturer's location. If the car rolls off the line without updates then in theory the updates could later be applied at the port but I don't think they do it there. So then the last chance is if the dealer proactively updates it but I don't think that's part of their process unless you ask them or they just have a high level of customer service and check for you anyway.
