Hi, I use up about one gallon of gas each month, so only fill up about every eighth month or so. So I would like to try to have as little gas in the tank at fill-up time as possible. Is it a smooth transition to run out of gas in HV mode? Will the car automatically transition to EV mode? Has anyone had positive or negative experiences doing so?
https://www.insideevsforum.com/community/index.php?threads/4216/ Sent from my SM-N960U using Inside EVs mobile app
Thanks David. Somehow when I put the question in the search box it didn't pull down your reference. Just to be explicit, I think you are confirming that if I have charge and I am running in HV and I run out of gas, the system will seamlessly switch the mode to EV, no longer displaying the HV icon.
It switched to EV - there were a variety of orange warnings flashing across the driver's display; but, there were no issues with the car running in EV mode. Once I put gas in it, and powered it back on, all was fine, and there were no warning on the driver's display.
