Racket when switching on
Discussion in 'Cooper SE' started by jeedc, Aug 5, 2022.
  1. jeedc
    jeedc New Member
    Hi All,
    We're a month into SE ownership now and I am going to buck the popular opinion on here and tell you that I don't really like the car. I especially don't like the regen braking and that bonging when the car is switched on. Does anyone know what that racket is?
    Thanks,
  2. tesrivmini
    tesrivmini Active Member
    Well there's the seatbelt warning bongs - these can be coded out with Bimmercode (which makes a nice difference), and the startup sound.
    jeedc and polyphonic like this.
  3. jeedc
    jeedc New Member
    Thanks @tesrivmini, it is the seatbelt sound. No need for it to start as soon as we switch on the car.
    I must look into Bimmercode
  4. revorg
    revorg Well-Known Member
    You've never had a car that told you to fasten your seatbelt before?
  5. jeedc
    jeedc New Member
    I have and indeed my car also does it but only when it starts moving. My *** has barely hit the seat and the mini is on my case about it - a bit too keen.
    J22 likes this.
  6. Puppethead
    Puppethead Well-Known Member
    Owning an EV brings the chance to unlearn a few habits. This is a case in point. With an ICE car it's normal to start the car, and then fasten the seatbelt. This gives the engine time to warm up before you drive off. But with an EV there's no need to warm up the motor, so a better habit is to fasten your seatbelt and then turn on the car. That completely eliminates the seatbelt warning.
    Not easy to unlearn habits, and it may not be the solution you're looking for, but it's certainly a legitimate way to start out in the SE.
    CrazyLegs17, J22, jeedc and 4 others like this.
  7. MarkSasaki
    MarkSasaki Active Member
    The seat belt warning was the first thing I coded out. I thought it was stupid because there are too many sounds going on at the same time. Maybe it would have been better if the timing of the warning was delayed after the startup sound, but they sound off at the same time and for me it was very irritating.
    JonR, jeedc and GvilleGuy like this.
  8. What is it you don't like about the regen braking? I've gotten to where using it has become second nature and I rather like it. That said, it would be nice if more settings were offered for it. As it is now, it's basically on or off.
    BigDawgMike and jeedc like this.
  9. Rexsio
    Rexsio Well-Known Member
    Sell to Carvana they going there for $40000 you pic up a wrong car which so many people LOVE IT !
  10. Rexsio
    Change your habit after few weeks you adjust and this can save your live
  11. Rexsio
    If you use low settings is the same if you take off a foot from ACE car is slowing down just change your habit is a learning curve about EVs and remember you don’t change a brake pads for 100000 miles
  12. polyphonic
    polyphonic Well-Known Member
    Can the lo-fi startup sound be coded out?? I would love to remove it too.
    Bimmercode can also remember your settings for drive mode and regen level. That might help?
    Like Rexsio said the used prices are crazy. You will probably make money by selling it.
    jeedc likes this.
  13. GvilleGuy
    GvilleGuy Well-Known Member
    Same here. I coded it out. Hated that klaxon sound over the SE startup tune. Much more peaceful now.
    MarkSasaki and jeedc like this.
  14. Rexsio
    How I decoded my wife screaming at me you guys so sensitive you must be a single not knowing how to go through life with stupid sound in a car to tell you use a belts to save your life .
    moofpup likes this.
  15. GvilleGuy
    I've been driving 35+ years and don't need a sound to remind me to buckle my seat belt. I enjoy hearing the pure startup sounds the designer composed without the warning chime drowning it out.
    polyphonic, jeedc and MarkSasaki like this.
  16. The air raid siren when you start the car is the seat belt warning. Who knows why it plays when you start the car rather than when you try to drive off or shift into gear.
    As for regen braking, it just takes some getting used to. I hated it at first, but now I pretty much only drive one-pedal.
    J22, polyphonic and jeedc like this.
  17. Minicris
    Minicris Member
    [QUOTE="
    Like Rexsio said the used prices are crazy. You will probably make money by selling it.[/QUOTE]
    Hard agree. We purchased used because we were too excited to wait the six months to get the mini we have on order. The price for the new is $4k more than what we paid for our used '22, but with rebates our brand new one will be considerably cheaper.
  18. polyphonic
    Wife was easy, we work to have a great relationship so no yelling is required ;)
    As for sounds, it’s just personal preference. I learned how to put my seatbelt on when I was 5 and haven’t forgotten since.
    revorg likes this.
  19. SameGuy
    YUL
    I just coded out almost all the warnings. Bliss.
  20. insightman
    You don't need to start the motor to get it warming up before you put on your seat belt. Assuming you're going to fasten your seatbelt anyway, why not just do that first, before pressing the Start/Stop button?
    If you don't want to fasten your seatbelt first because you want to listen to the radio the instant you're in your seat, you can activate standby state by pressing the Start/Stop button without depressing the brake pedal. Then, after fastening your seatbelt, depress brake pedal and press the Start/Stop button again to activate drive ready state.
    I've suggested this procedure before, but was rebuffed with the rebuffer claiming that pressing the Start/Stop button twice is just too much. For those who don't want to press the Start/Stop button twice, it's good that Bimmercode can solve their problem.
    GvilleGuy and revorg like this.
