Problem changing key fob battery
Discussion in 'Clarity' started by Tangible, Dec 10, 2020.
  1. Tangible
    Tangible Active Member
    The 2032 battery in my key died, and I followed the instructions to pry the fob apart. I replaced the battery, but now when I try to snap the case back together it resists and then starts the panic alarm.
    Any hints on getting this done without waking the neighborhood ?
  3. Skynosaur
    Skynosaur Member
    Check if the buttons line up and you're not snapping the silicone.
    Sent from my G8142 using Tapatalk
  4. jdonalds
    I'm assuming you have the battery in the correct orientation?
  5. insightman
    Walk far down the block before trying to snap the fob case closed. If you're sending the panic signal you must have the battery +/- oriented correctly. The fob battery swap went so easily for me that I can't offer any other tips.
    DaleL and Louis Nisenbaum like this.
  6. Tangible
    Thanks, folks. I finally got it. Everything was properly oriented, so the "try, try again" method eventually worked. Amazing what a piece of junk it is. For what they charge for these they could afford better, one would think.
    I can't wait for the time when our phones and watches will replace these pocket-bulging monstrosities. Apple has already announced their approach (CarKey), but it will take a long time for the manufacturers to start incorporating it, and whatever Android develops, I think.
    Mowcowbell likes this.
  8. leehinde
    leehinde Active Member
    These guys are my go to for any battery in a gadget. https://www.batteriesplus.com/. They replace it for you for the cost of the battery and since they do it 20 times a day and not once every 24 months, they typically don't break anything.
    Tangible likes this.
  9. Mowcowbell
    Mowcowbell Well-Known Member
    Totally agree on the need for Android and Apple phone apps for vehicles. Follow Tesla's lead and get us away from these super expensive key fobs!
  10. PHEVDave
    PHEVDave Active Member
    Actually, I just saw a commercial on TV the other night. The pet dog buries all the key fobs in the yard and the wife just uses her phone to unlock the car and start it.
