2018 Clarity 10k miles. All the electronic driving systems are coming up as having an issue. I plugged my car into a charger at a local municipal building with 3 double connections stations. I've never used the evconnect before so seeing the screen display "call service for support" meant nothing since blink chargers will say that something along those lines. I tried sending a signal to connect through their app and also through the Honda Link app since that has helped start a charge. After several failed attempts I tried the other connector and same thing. After I noticed the other stations had a different screen, I unplugged my car to move it closer and i was greeted with all of these alerts and the car wouldn’t start. Electronic Break system failure TPMS Plug-in Charging System Break system Vehicle Stability Hill Assist Power steering Road departure warning Collision mitigation I can’t drive the car but the stereo works. I had to push the car in neutral toward the other station and it is receiving a charge. I am going to try and disconnect the 12V battery.
Sad first post for you. Let us know how you fare. I've had the cycling every message in the book error a couple of times, but never had the car lock up with them. It just set the check engine light for a couple of drives and then all clear again. I hope the 12V battery disconnect got you going so you could avoid the tow.
