New software available
Discussion in 'Kia Niro' started by JBW11, Nov 11, 2021.
  1. @Crash Do you have a howto someplace on how to update through the USB port instead of slipping the new flash card into the system?
  3. Crash
    Crash Member
    The official Kia site gives all the details (do not recall the exact subpage): Notice | Official Kia Navigation Update Website
    I have done it once or twice. In general, you just have to download the update and place it on the USB stick.
  4. JasonG
    JasonG Member
    Exactly, I initially bought it on the 32 GB SD card so I have a couple of extra ones that I download the update to and insert into the car for the update.
    The update software is pretty easy to use and you can just log in as guest. Just follow the same instructions as when you buy it on the SD card.
  5. Raleigh Ron
    Raleigh Ron Member
    If you haven't run the Kia Navigation software updater recently (I sure haven't!), here's some news:
    There's a new version of the maps and software dated April 28, 2022.
    It claims to have better support for wireless Apple CarPlay and Android Auto, the ability to choose a dark Nav background as default, and some improvement in communication via the Kia Access (UVO) App.
  6. Robert Besen
    Robert Besen Member
    Looks like the latest nav update requires a usb drive larger than 32GB. Is this right or am I doing something wrong?
  8. Raleigh Ron
    Raleigh Ron Member
    Yes, the installer software says the Data Size is 31GB, with required hard disk space of 52GB. That means you need at least 52GB on your C: drive, because of temporary files. But when you get to the step that formats and copies files to your USB drive, you'll only need 31.7GB. I used a 64GB USB drive, but you should be OK with a 32GB USB drive.
  9. Robert Besen
    Robert Besen Member
    Thanks for your reply. I tried a 32gb thumb drive and the installer software said "insufficient storage space on portable device". Also said the data size was 35GB, and the required hard drive space is 59gb. I've got a 2020 niro ev premium (with the wide screen), and my computer is 64 bit windows 10. So something is different in my setup. I'm going to BestBuy shortly to buy a 64gb drive; about $10 for USB 3.0.
  10. JasonG
    JasonG Member
    It looks like there is an "audio update" which is separate from the maps update. Do I need to do both updates? Does the audio update allow for wireless Apple carplay on a 2019 Niro EV?
    Has anyone done this?
    Thanks
  11. Wireless car play is a hardware upgrade, new head unit not a software upgrade.
  13. JasonG
    JasonG Member
    OK, thanks. However, whatever audio updates are included are also in the maps and software update, correct?
  14. Stuart Clark
    Stuart Clark New Member
    Hi Kevin. I have a 2022 Niro in Whitehorse and want to be able to do my own updates (the dealer insists that this isn't possible). I downloaded the most recent update file but note that the file title includes 'US'. Did you use such a file on a Canadian vehicle?
  15. GeorgeT
    GeorgeT New Member
  16. Stuart Clark
    Having been assured by Hyandai AutoEver (?) that the update file was correct for my 2022 Kia Niro EV, I loaded the files onto a 64 GB USB memory key. My car told me there were 'No supported files'. Noting that the key was formatted exFAT, I reformatted to Large FAT32 thinking that may be the problem. Same result in the car. What is the meaning of 'No supported files'?
  17. CR EV
    CR EV Active Member
    My guess is that the system doesn't like the formatting. This one worked out of the box via Amazon:
    SanDisk 32GB Ultra SDHC UHS-I Memory Card - 120MB/s, C10, U1, Full HD, SD Card - SDSDUN4-032G-GN6IN
  18. Stuart Clark
    Thanks CR EV for your suggestion. A couple of followups - I don't think my Niro has a socket for memory cards - only USB key and this update requires 50 GB of space so would have to be larger. Still, you may be right that I bought a cheap 64GB key. Perhaps I will try with a better quality one.
  19. CR EV
    CR EV Active Member
    My 2019 uses an SD card. Have you checked the manual...asking just in case...
