Modifications and Tweaks
Discussion in 'Hyundai Kona Electric' started by electriceddy, Mar 10, 2019.
  1. With the sloppy driving conditions of late, I notice my rear camera lens is always mucked up with grime. I did a little searching, and found a fellow who managed to install a rear camera washer in his Ioniq. (https://www.ioniqforum.com/threads/rear-view-camera-washer.35595/)
    He didn’t have a rear washer or wiper, unlike the Kona, so I figured it shouldn’t be that hard to install a second washer nozzle on my car. I headed to Napa and picked up a 3/16” straight washer hose connector, a 3/16” Y connector, 8 feet of washer hose, and a check valve. Total cost $25. Then I picked up 2 (1 for a spare) 18 gauge needles from the pharmacy ($3). As it turns out the Napa check valve didn’t work after first installation and testing. :mad: I ended up ordering and using a Kona stock rear washer check valve (Hyundai p/n: 9888629000) from the dealer for $7.
    On the rear hatch door, I popped off the top interior trim, the door handle insert, and then the bottom trim panel (there is 1 plastic screw to remove at the bottom), and unscrewed and popped off the side trim panel on the passenger side. Everything is held with standard vehicle push in plastic connectors. Next, I undid the four 10mm nuts holding the rear latch assembly and squeezed the 2 orange plastic pop-in connectors to remove the assembly. There is one electrical connector to disconnect that feeds the camera, license lights and the latch release button.
    The wires feed through a rubber grommet that pops out, enabling the assembly to be placed on the bench.
    From the inside of the latch assembly, centered on the camera lens, I drilled a 1/16” hole through the plastic to insert the needle nozzle. Then, clipped the needle’s plastic flange so it would fit inside the washer hose, and then used a Dremel to cut the needle to length, and rounded the edges. I bent the needle slightly so it stays close to the lens and would spray on it. (This was the fiddliest bit of the whole process; I blew water through the hose and needle a few times until I was happy. Rubber washer hose water doesn’t taste good, by the way….). The nozzle is close enough to the camera that you don’t snag on it.
    I secured the needle and hose under the camera, then rerouted the camera cable to make room for the washer hose over to the grommet. I poked a new hole in the grommet, and squeezed the hose through, taping the wire and hose together with electrical tape. The grommet seal is tight to the washer hose. Then I cut the hose in the latch assembly and inserted (on the second attempt) the Hyundai check valve (white side towards the nozzle). This basically prevents the hose from draining when the washer pump is not pushing fluid.
    I reinstalled the rubber grommet and latch assembly and then cut the hose to insert a straight 3/16” hose connector, so that in the future the latch assembly could be removed by disconnecting the electrical plug and decoupling this fitting. 06_stright grammet.jpg
    I ran the hose above the tail light, then between the metal and the plastic trim to the top of the window.
    There, I disconnected the original check valve for the top sprayer, and made up a Y to divert the washer fluid to both nozzles. The top check valve is closest to the sprayer, and the Y permits unrestricted flow to the camera check valve.
    I tested the installation, and when activating the rear washer, it sprays well on both nozzles. I took a quick drive to ensure the moving air didn’t suck out the fluid, and then reinstalled all the interior trim. Overall, I’m pleased with the install, and the nozzle is not noticeable unless you look for it.
    Hope this helps anyone looking to try a similar project!
    Renew Able, TugBoat, mho and 11 others like this.
  3. XtsKonaTrooper
    Looks slick, I might have to do this.
    I see your fm NB, what kind of range are you getting?
  4. This might be the definition of insanity. ;)
  5. Of late, since I travel on the highway at 115 km/h to and from work, use winter tires, and I don't skimp on my heat settings, I've been seeing ~24 kw/100 km consumption. When I first got the car in October, I was around 19.6 kW/100 km.
    XtsKonaTrooper likes this.
  6. XtsKonaTrooper
    I haven't checked that lately .
    But avg about 330km per full charge with your similar driving habits.
    Instead of using the heat as much on long hwy runs, , I also use an electric blanket as it runs off the 12v battery.
  8. Thanks for those pictures.
    I was sure of the existence of a rear door latch switch, and your first picture shows it is there, and easy to disconnect. (similar to the one in the front for the hood). I intend to disconnect/bypass mine this summer to avoid any unwanted issues causing the battery to go dead with a not proper closed hatch, also to drive with the tailgate open (carrying a long load) without the dash warning):)
    navguy12 likes this.
  9. Tomek
    Tomek Active Member
    A very elegant solution, it is strange that the manufacturer did not do it at the factory.
  10. TerryFolds
    TerryFolds New Member
    Great writeup. Wish I saw it before I did my install- I ended up doing it almost identical, except for going down the passenger side for the rear cam. I also tried the heated steering wheel fuse, heated mirror fuse, and second power outlet fuse all with no luck. I finally got it working with the 30a "AMP" fuse (assuming for the audio system).
  11. Looks like we are still good to go until 2023 in Canada:
    https://electricautonomy.ca/2021/05/13/ev-noise-sound-requirements/
    Became law in U.S. year of 2018.
    navguy12 and Domenick like this.
  13. This isn’t really a mod to the car, but rather something I found that makes longer drives more comfortable. Our cottage is about a 3 hour drive away, and I like to rest my arms on something while driving. I can rest my left arm on the door OK, but the right side has no such option.
    I found this portable armrest on Amazon:
    https://www.amazon.ca/CDEFG-Extender-Organizer-Adjustable-Universal/dp/B08131G3Q7/
    I chose black with white stitching to match. It is height adjustable, and I flipped the armrest so it juts out over the centre console instead of into the driver. The bottom plastic part wedges in fine between the seat and the console. I only put it in for long drives, since it does make it a little hard to reach the cooled/heated seats button, blocks the centre storage box, and you can feel it on your right butt cheek, but overall, a big thumbs up from me for comfort!
  14. I managed to tear off those visors before trading in my 2019 model last October. The weather was above 70 degrees yesterday so I reinstalled them back on to my 21 model. Total cost...$8.46 for some 3m heavy duty tape:)
    Only exception was the 2 little ones that are cosmetic only for the rear (non opening) small window (they cracked when I took them off as the temperature at the time was cold) no big deal
    I notice they are still available, if you are interested, here is the link:
    https://www.amazon.ca/Clover-Weather-Deflector-Compatible-Hyundai/dp/B07L6DKTCM/ref=sr_1_fkmr2_1?keywords=well+visors+hyundai+kona&qid=1552258047&s=gateway&sr=8-1-fkmr2
    mho, Danhen, Domenick and 1 other person like this.
  15. My previous Elantra GT had three 12V outlets, one in the rear hatch area. I miss the convenience of it, so I purchased an add-on 12V outlet from Canadian Tire, and started an afternoon project. Since the left rear panel would need to be removed, I also decided to do something with the light. My previous Toyota Echo hatchback had a rear light with a toggle switch embedded, so you could decide to activate the light. A simple toggle switch was also picked up at CT, mainly because that was the only one that would mount in a plastic panel easily.
    After emptying the hatch area, I removed the 2 pop out black plugs on the rear bottom panel, then snapped out the 4 push-in plastic connectors holding it in place.
    Next, 3 Phillips screws were removed from the bottom of the left rear panel, and a few sharp pulls snapped out some more push-in plastic connectors at the rear edge. I didn’t need to remove the whole panel, so I just propped it open. The lamp power connector simply disconnected by pulling it down.
    The 12V outlet I bought needed about 2.5 inches behind the panel for the plug and wire connection, so after measuring a probe hole, I chose the flat spot ahead of the net hook.
    I ran the 12V black lead to a 10 mm nut holding down the amp, and fished the 12V red to the rear door.
    The rubber door trim pulls off easily, so I simply fished the red positive along the bottom of the drivers’ side doors until I made it to the fuse block. There, a “micro” add-a-fuse (from Amazon) with a 10A fuse was added onto a switched circuit. Tested the circuit with the car off, then on, and all good!
    With the panel still pulled off, I then cut the 12V + wire leading to the rear hatch light.
    I soldered and shrink-tubed some longer wires that were then connected to the toggle switch, and inserted in a flat spot out of the way by the light. When ‘on’, the light works normally with the hatch opening, and when ‘off’, the light won’t light up, so you can leave the hatch open without draining the 12V battery.
    I snapped the panels back on, with the screws and plugs, and done!
    Hope this gives folks ideas for a similar project!
    navguy12 and John Lumsden like this.
  16. Front grille rock guard, a preventative measure to help avoid a small rock or road debris from puncturing the exposed radiator core when the dampers are open. Install time: 45 minutes to 1 hour, cost: less than $5.
    Start by cutting a piece of black plastic leaf gutter guard. The grille hole on the Kona is 5" wide @ center and 4 3/4" wide at the edges. The length varies from 24.5" at the top to 22.5" wide at the bottom (slanted edges). Mask the edges on the leaf guard to allow 1/2" extra material on the top and bottom (basically center the piece on the 6.5" leaf guard material, the extra material will slide into the top slot and bottom slot behind the grille opening after installation, and provides additional support. This is an example of the material I used:
    Once you have cut the piece to above spec, the whole piece can be maneuvered into the bottom slot behind the grille from either side. (The slots that I am talking about is the gap between the car body and the nose on the top and bottom). Carefully slide the material sideways behind the radar center portion until it covers the whole opening. As stated above the piece will have about 1/2" tucked in above and below, At this point you can now add the ty-wraps (8) total for support, snug and trim the tails and position the clasps under toward the back where it is less noticeable. All I had on hand were 8" black U/V rated ty-wraps so I installed them and are slightly noticeable, so I will change them to 4" skinny ones next time I am at the hardware store and they should blend in better, But for now... here is what it looks like:
    Center
    Right side
    Left side
    The material sits flat and well supported to the nose portion of the grille opening and has no affect on the operation of the dampers:)
  17. Danhen
    Danhen Active Member
    I like that a lot electriceddy!
  18. Thank you, it should look better when I install the smaller (thinner) ty-wraps.
    mho and Danhen like this.
  19. Unfortunately the Ministry of Leaf Gutter Guards has deemed that they will be 2cm in pitch here in NZ so I can't get the 1cm stuff any more. I'm amazed you were able to do that without disassembly and the jaunty 45° angle looks great.
    mho, electriceddy and navguy12 like this.
  20. Its starting to grow on me, looks excellent. I did change out the ty wraps to the thinner 4" ones today and are less noticeable. I also tested the radar (the material is not cut in front of the radar unit) and it works well. I had visions of possibly tearing it out and cutting a square section where the radar is, but not required. It's funny as the actual radar component is set back a small bit from the front nose section, allowing one to drag the flexible plastic leaf guard material across when installing, without this, things would have been a lot tougher.
    Here is a rough copy of my original design template, it may save a little work for anyone who may want to do this. If the nose cone is removed (for whatever reason) it would pay well to have one pre-made as installation from the back side could be done a lot easier with the use of a few clips.;)
    BTW maybe its time to elect a new leaf gutter guard minister:D
    KonaAU, mho, KiwiME and 1 other person like this.
  21. Picchip
    Picchip New Member
    I want to thank you for doing the heavy lifting to get this to work. I added my own twist to the project. I also have a lease and did not want to drill any holes or leave any evidence of the modification that may be used agents me to void any warranty or get some kind of up charge when the car was returned or just serviced. So my version was to use normally open magnetic reed switch. I opened the button assembly and found the connections on the circuit board. Soldered wires to the connector pcb pins and the reed switch inside the switch assembly. I then mounted the read switch behind the un-used blank switch plate. Re-assembled the button assembly and there is no visible changes to the car. Now swiping a small magnet past the unsuspecting blank switch panel will trigger the mute of the VESS.
    IMG_2200.jpg IMG_2201.jpg IMG_2206.jpg IMG_2207.jpg IMG_2212.jpg IMG_2216.jpg IMG_2217.jpg IMG_2218.jpg IMG_3234.jpg
    KonaAU, dark night, mho and 5 others like this.
  22. Good idea and a stealthy mod!
  23. EnerG
    EnerG Active Member
    Brilliant. This is a much needed mod. Has there been any clouding of the lens from the alcohol in the washer fluid?
