MINI says State Vehicle Inspection needed?!
Discussion in 'Cooper SE' started by quietlyspinach, May 4, 2025.
  1. quietlyspinach
    quietlyspinach Active Member
    So my MINI, at its 4th year anniversary, has told me that a State Vehicle Inspection is required, along with the 2nd brake fluid exchange.
    I'm trying to research what this could possibly be, and the only explanation I can come up with is that this is the Smog Check Vehicle inspection alert that normally only shows up for the gas vehicles and maybe they forgot to remove it from the electric versions.
    Does anyone else know what this could be about? I'm in California.
    KellyTheK and ghost like this.
  2. Alf_W
    Alf_W Active Member
    Makes no sense to me. Even gas cars newer than eight years do not need smog check, so even a mixup with gas cars would not explain it.
    I’m in CA also, interested in what you find out.
  3. MrSnrub
    MrSnrub Well-Known Member
    Smells like bullshit
  4. Alf_W
    Alf_W Active Member
    ghost likes this.
  5. jwzimm
    jwzimm Active Member
    The "state inspection required" notification is just a time-based feature in the car. For an example, I live in Washington State which does not have any state inspections. I still have this interval reminder in the system (I think it was set at four years). The below link implies that the dealer is supposed to set this but I would hazard a guess that they don't really do that:
    https://dealers.miniusa.com/content/dam/mini/PDF/warranties/2023_MINI_Maintenance.pdf
    quietlyspinach likes this.
  6. pictsidhe
    pictsidhe Well-Known Member
    My SE needs an annual safety inspection here in NC. The smog check only goes as far as checking that it does not have a gas engine. Other states no doubt vary.
