Mini Connected - Pre Conditioning Function
Discussion in 'Cooper SE' started by Tommy Electric, Oct 21, 2020.
  1. Tommy Electric
    Tommy Electric Active Member
    For those lucky forum members who've already taken delivery of their SE, I was curious to learn about your experiences with the "Mini Connected" app. In particular, I wanted to know the following:
    1) When preconditioning the car via your cell phone, are you able to set and adjust the cabin temperature from within the app?
    2) Can you use the app. to check charging status and stop charging?
    As far as I know, the app also allows you to lock/unlock the car, check car location and turn the headlights on/off. Am I missing anything else?
    It's not exactly Tesla-level functionality but this seems like it might be quite a useful little app.
    Thanks!
    GvilleGuy likes this.
  3. Toi
    Toi Well-Known Member
    1. No, it just does 'a comfortable temperature '
    2. Yes, you can check status, but not stop.
    Other functions you got, but add honk horn to the list, and see your efficiency ratings.
  4. HenryCooper
    HenryCooper New Member
    Yes you can stop the charging by changing it to “Charge with off-peak tariff”....just set the timer to start and stop at the same time.
  5. Toi
    I haven't seen that option in my version of the app, only in the car itself.
  6. Tommy Electric
    Do you have any idea what "comfortable" is in terms of temperature? I'm a little surprised they don't let you set your desired temperature.
  8. Toi
    Felt like 72F (20C)
    Tommy Electric likes this.
  9. Tommy Electric
    Well, if you can't adjust the temperature I guess that setting makes the most sense. Thanks for the info! I'm going to enjoy playing with the app once mine arrives. I hope you're enjoying yours.
  10. GvilleGuy
    GvilleGuy Well-Known Member
    In South Carolina summer heat, I would definitely say "a comfortable temperature" is close enough to keep my face from melting off. I'm glad it is a feature.
  11. MichaelC
    MichaelC Well-Known Member
    Hrm. I'll have to double-check this, but I thought it used the last temperature you set it to while in-cabin.
    Tommy Electric and Toi like this.
  13. Puppethead
    Puppethead Well-Known Member
    That was my understanding as well. When on a rollercoaster of temperature a few weeks ago (80ºF during the day, 45ºF at night), I'd constantly adjust cabin temperature to minimize activation of heating/cooling while driving. But I'd often forget and leave cabin temperature set to 76ºF (to keep air conditioner under control during the hot time of day), and then in the morning after preconditioning it would feel hot inside.
    I've also read somewhere that if the departure time is greater than three hours away the battery pack will be preconditioned, otherwise just the cabin temperature is adjusted. This might be how the BMW i3 behaves so I don't know if the SE is the same.
  14. Tommy Electric
    This would be interesting to know @MichaelC
  15. MichaelC
    Method:
    1. "Start" the car.
    2. Set driver's side to a "warmer" temperature (like 75F).
    3. Set passenger's side to a "cooler" temperature (like 65F).
    4. Turn car "off".
    5. Exit car.
    6. Send "Climatize Now" command and wait a few minutes.
    7. Get in car and observe how the HVAC is behaving.
    At this point, both driver & passenger sides were blowing the same moderate/cool air.
    When I "start" the car again, each side altered its behavior to reflect the manual settings selected in steps 2 & 3.
    Conclusion: It seems like the "Climatize Now" uses a default "comfortable" setting. Agree with @Toi that it seems like 72F.
  16. Tommy Electric
    Thanks! Nice little experiment.
    Toi and MichaelC like this.
  17. MichaelC
    BTW, that test was on battery power.
    I'll try a scheduled departure while plugged into the EVSE this weekend, and see if that behaves any differently.
    GvilleGuy and Toi like this.
  18. HenryCooper
    MichaelC likes this.
  19. GvilleGuy
    I wonder if the app is smart enough to know whether you have off peak rate discounts available and hides the options. My power company does not offer any discounts yet.
  20. Toi
    Ah joy, another instance of the apple and Android versions are different...
  21. Puppethead
    Drove my car today for the first time in three days (still snowing, but roads are clear). When I got in my car this morning I noticed it was rather cool inside the cabin, and the display said something along the lines of "Cabin comfort not performed to protect the battery. A short drive will resolve this." I regret not having the presence of mind to take a photo.
    My car has been plugged in the whole time, sitting at 100% SoC for most of the time. I wonder if the car was referring to the 12V battery?
    Toi likes this.
  22. Toi
    Yeah, the 12V battery runs the fan and the heat pump systems, but the 12V battery doesn't get a charge unless the car is 'on' even if plugged in.
  23. insightman
    Perhaps if you set a departure time for at least a few hours ahead of the current time, your plugged-in MINI Cooper SE would warm the battery (and then warm the cabin, too). I would be surprised if the car was protecting its 12-Volt battery and even more surprised if your 12-Volt battery's charge was depleted in just 3 days without driving the car.
    F14Scott likes this.
