Midyear Changes
Discussion in 'Cooper SE' started by bfl, May 22, 2022.
  1. mm that's weird maybe it was a year or two ago but it was like a $500 add on the online builder BUT I could be wrong.. but glad it's a free choice now.
  3. methorian
    methorian Well-Known Member
    That person never mentioned their costs, so I'm unsure. I haven't seen any mention of price changes though, so I'd assume they're still the same.
    bfl likes this.
  4. insightman
    It would be fun if AutoCAD had an article about how the 2024 SE was designed. The AutoCar article revealed this interesting design statement:
    The aim is to reduce the design to what matters and rely less on chrome and stylistic flourishes.
    Guess I bought my SE 3 years too early if I didn't want to spend nearly $2K to get rid of the stylistic flourish that is the fake hood scoop.
    Other than the fake hood scoop, I like all the other stylistic flourishes on my 2021 SE. There are plenty of other minimalistic cars out there already so "cleaning up" the MINI Cooper will make it less distinctive. My current SE's anachronistic switches, buttons, and knobs on the dash and headliner all make a lot of sense to me. Dispensing with these haptic, easy-to-locate controls in favor of a large, circular screen that replaces these controls doesn't appeal to me. And why a circular screen if they're eschewing stylistic flourishes?
    MINI will have a difficult time making the 2024 MINI Cooper as minimalistic as Alec Issigonis' original.
    idesignstuff, PSGee, Rogwp and 3 others like this.
  5. Waiting for my Mini SE delivery. The "variable light decoding" can be recoded with Bimmercode. I did this on my 2021 530eX. Works great.
    idesignstuff likes this.
  6. To remove this ad click here.
  7. insightman
    Please explain to the Bimmercode users on this thread how to do that with their MINI Cooper SE. If you're right, I'll become a Bimmercode user.
  8. jwzimm
    jwzimm Active Member
    Agreed, I to would be curious about the process and results of this on the SE. While the VLD and NGHB coding on the 5-series is well known and proven out I have yet to find any information/confirmation on the changes needed to activate it on the Cooper SE.
    From my previous coding days (using laptop and eSYS) I know you would be able to simply edit the VO and delete the 8S4 option in the VO and then default code the car. That "should" activate (more disable the deactivation of) the VLD. Can Bimmercode modify the VO and code the car like this? I do not think the VLD activation is in the list of codable options in Bimmercode so you would need to know what specific codes need to be modified in what modules and use expertmode. What would work the best is to obtain the trace files from a UK or EU Mini SE that has the matrix headlights active and compare them to the US version.
    tesrivmini likes this.
  9. Here you go...
    See attached .pdf
  10. SameGuy
    YUL
    And it works on an F56 LCI2?
  12. I have not tried it as I'm waiting for delivery of my Mini SE. That being said, I do remember reading a post that said it worked on a Mini.
  13. indiejayy
    indiejayy New Member
    My dealer told me they removed the 16" revolite grey wheels anymore in 2.0 which I kind of figured would get me more miles than any of the 17". all other options in Iconic 2.0 seem the same for me.
  14. Puppethead
    Puppethead Well-Known Member
    Whoa, I thought those were the default wheels for non-Iconic. What's replacing them? The US build site still shows them.
    The 17" Power Spokes are very efficient and don't impact range. I run the Power Spokes during the summer and Spectre Grey Revolites in winter.
  15. insightman
    I like my Power Spokes so much I drive on them just one day a year. MINI says they're their lightest 17" rims and I'm sure they're also the most aerodynamic. However, are they still reserved for the Iconic trim or does 2.0 make them available for the Signature Plus? The 2024 rumors say "larger wheels" so I doubt the 17" Power Spokes will continue. If MINI has a large stash of them, maybe they'd be willing put them on Signature Plus, too.
    Will the 2024 SE continue with the F56's 5 × 112 wheel-mounting pattern? I wonder what pattern the Ora Good Cat uses?
    teslarati97 and endquote like this.
  16. drdunkyn
    drdunkyn Well-Known Member
    Pretty sure we're way past the true minimalist ideal :D
  17. drdunkyn
    Also, I LOVE the adaptive headlights. I haven't messed with them on Bimmercode since they came standard on my 22 Iconic. Had them on my last car and would never go back. Those few degrees of additional lighting in a turn is super helpful. I'll go back and look at what B-code offers, but since a lot of the changes require a "headunit reset" which means resetting all the preset buttons, I'm not going to be testing it. I'm a set-it-and-forget-it guy!
  18. indiejayy
    My dealer sent me this when I clarified what is the Driver Assistant package in my Iconic 2.0 package.. It looks like Active Cruise Control will be removed, however Heated Steering was on my quote sheet but may be removed later...
    Louis W, bfl and insightman like this.
  19. Torrey
    Torrey Active Member
    Different system. All Mini’s have the lights that illuminate corners and auto high beams. Adaptive headlights allow you to run high beams all the time and reduce the illumination only in the direction of other drivers. It is like super auto high beams. Up until recently it was not allowed under US regulations. More sophisticated system like Audi’s can project images and words with the headlights.
  20. drdunkyn
    Interesting, in BMW Adaptive Headlights refer to the ability to pivot the lights in cornering. Didn't realize it was the Matrix changes that happen in the MINI
  21. indiejayy
    He switched mine to 16" Victory spoke as those were the only other 16" I guess. It's still Revolite on the website though. I wonder if it's just my timing... Not sure I'm convinced on the Power Spokes as they don't look balanced and I read that it requires a special balancing device? Also it looks like a conversation piece whether it's a UK plug or a cross.. As with the other thread on wheel options, I hope they come up with more aero options.. For now I'm thinking of the rail or scissor spoke...
  22. SameGuy
    YUL
    My wife thinks “cross” and I think “stylized UK (G) outlet.” ¯\_(ツ)_/¯
