I'm new here -- my 7,000 mile review, including 4,200 mile road trip
Discussion in 'Clarity' started by craze1cars, Nov 8, 2018.
  1. WantEV
    WantEV Member
    I guess you're correct, if the car tries to keep a minimum battery reserve. Thanks for a nice travel journal!
  3. craze1cars
    craze1cars Well-Known Member
    Thanks KentuckyKen for sharing that tip...I never considered that. I would just press the gas pedal and no big deal, but might keep your method in mind. I guess it makes sense that it is likely the econ mode thing that is likely slowing response from the car.
  4. insightman
    It may ultimately require the same amount of energy to make a trip with a full battery vs a depleted battery, but giving the Clarity some battery power to play with while you drive in HV Mode certainly makes for a more pleasant driving experience. Also, it's good to have some battery power in reserve to climb hills or pass slower cars.
  5. craze1cars
    Honestly I did it both ways on this road trip, and didn't notice any substantial difference at all in driving experience or passing/hill power. Whether I had dead battery in forced HV mode, or 3/4 battery in selected HV mode. Angry bees seemed to react the same way in both modes in similar driving situations, and mpg was comparable.
    I am only assuming that's part of the reason the battery meter bottoms out at 2 bars -- it seems Honda has programmed in a reserve for such instances, so the battery is never truly "dead" as I have been saying...meaning no vehicle performance is lost? Admittedly I don't know the answer, but my experience on this trip seems to indicate what I believe to be true is true...
    Viking79 likes this.
  6. leehinde
    leehinde Active Member
    Ditto; I'd read early on you need to be in sport mode to get the quicker re-acceleration. But I found normal Drive mode worked as well.
  8. insightman
    You are correct that the Clarity will not allow the battery to be completely discharged because that causes a Li-Ion battery to die. The lowest number of bars reported on this forum is one and I believe only one forum member has managed to deplete the battery that much. There is also a buffer at the top end that prevents overcharging. Many on this forum report that a full charge is 14.4 kWh, not the nominal 17 kWh capacity of the battery.
    The engine alone generates up to 103 horsepower. There must be system losses as the engine turns the starter motor/generator to power the traction motor, so fewer than 103 horsepower actually make it to the road.
    When the engine is not running, the traction motor can deliver up to 121 horsepower. The traction motor can produce as much as 181 horsepower when receiving power from both the engine/starter motor/generator and the battery. Although Honda says the Clarity can produce 212 horsepower, only 181 horses are available when you really get on it.
    I have personally never heard the "angry bees" in 11 months of Clarity driving, but there are no big hills to climb in south-east Michigan so the engine has never been pushed very hard. I do believe the engine is louder when it is powering the car without assistance from the battery. I'm sure this increased volume is due to higher revs.
    When battery power is available, the Clarity in HV mode can select from three different underlying modes of propulsion: EV drive mode, Hybrid drive mode, and Engine drive mode. The car selects whichever one of these modes offers the greatest efficiency at a given moment. It is often a mystery how the Clarity chooses between these 3 drive modes, but I find it satisfying to know the car is utilizing all of its resources and technologies to get me to my destination in the most efficient manner it can provide.
    For the above reasons, I feel the driving experience is better when the battery is not depleted.
  9. neal adkins
    neal adkins Active Member
    When I go on a long road trip I plan to take a small gas can just to be safe. Hopefully it will fit safely in the Cable storage box in the trunk. Any recommendations?
  10. lanb
    lanb Active Member
    I don't think you would need it. Pretty sure that even at the low 190 Miles for 7 gallons, you will find a gas station well before you empty the tank.
    BTW, we drove from LA to Las Vegas (290 miles) on 6 gallons of gas starting with a full battery and ending with 3/4 battery.
    All in HV mode around 65-70 MPH and averaging 48 MPG.
  11. neal adkins
    About 98 percent of the time I agree with you. But I remember driving across Texas and there was about a 300 to 400 mile stretch with no gas stations. The speed limit is also 80mph.
  13. weave
    weave Active Member
    I really think that with the small tank, weight, and bulkiness of the vehicle, that by going 80 MPH you are probably wasting time having to stop for gas so often over just doing about 70 and stopping less often. I drive across I-20 and I-10 in TX where it's 80 about once a year in a Kia and the gas mileage would drop from about 34 down to 26 doing 85. I also noticed that all the locals (mainly pickups) would never be going to speed limit.
    But that's logic. When you're on that road, especially west of Pecos, it gets really boring and you just want to get it over with and get to El Paso.
  14. craze1cars
    Just respect the fact that the "miles to empty" range thing is wrong, keep an eye on the gas tank, and with Gas Buddy app these days on your phone you'll always know where every gas station in the country is located. Plan ahead in the truly remote areas. People seem to be focusing on my one-time fluke of a 190-200 mile range. This was NOT typical for the trip...it was essentially a one-time thing. Don't sweat it. And instead of a dangerous and smelly backup fuel can in the trunk, why not just start with a full battery and don't use it? A mostly full battery is a very effective backup fuel tank if you really find yourself in a pinch. Slow down a bit to 70 mph and the car gets 40+ mpg. Slow down quite a bit more to 60 mph more and it gets nearly 50 mpg. These are also effective backup plans if you know you're heading "into the darkness" with possibly no fuel to purchase. Heck every single person you see towing a big camper/trailer with a pickup truck or SUV is getting 10 mpg, and many of them have a 26 gallon fuel tanks. Trust me on that, I own one and drive it cross country frequently. And they ALL need to stop for fuel every 240 miles. Just like the Clarity might need to do. The difference is at $2.50/gallon you're gonna pay $15 at the pump each time, and they're gonna pay about $60...but they have the same range and they all make it to their destination without extra fuel cans on board.
  15. Electra
    Electra Active Member
    I think you're exaggerating the distance. That seems too far in this day and age. Some cars cannot go over 300 miles per tank. There won't be any motorcycles on that road.
  16. dnb
    dnb Active Member
    Yeah my old Accord got ~320 to a full tank (12gal?) 400 miles without a gas station seems unlikely.
  17. rodeknyt
    rodeknyt Active Member
    Where did you come up with only 190 miles on a full 7 gallons of gas? We recently finished a nearly 4,000 mile road trip (using HV mode almost exclusively) and usually went 230+ miles on around 5-5.5 gallons. You would have to be driving continuously up an 8% grade for three hours to do that bad.
  18. SkipperT
    SkipperT Member
    Personally, it just makes sense to stop, stretch and pee that frequently anyway!
    -Skip
  19. lanb
    lanb Active Member
    I didn't, this was the worst mileage that OP had posted on his 7000 mile review. I was using that to answer neal adkins question about having a spare gas can in the car.
    Yes, it is not a common occurrence and happened only once to the OP. Basically, a worst case scenario.
