Has anyone replaced the brake rotors yet?
Discussion in 'Clarity' started by Casey Martin, Oct 26, 2021.
  1. NorthernClarity
    NorthernClarity New Member
    Leehoewonek I just had my 2018 (only 39500 km) in for a brake service and I'm in the same boat you were in where they are recommending all discs and pads be replaced. Did you have to contact Honda Canada directly for them to cover it or was that done through the dealer? Just trying to find out how to approach this. Thank you.
  3. leehoewonek
    leehoewonek Member
    Hi,
    I had to contact Honda Canada myself,and after I did so they contacted the dealer and made all the arrangements for payment. You're out of warranty now, but discs aren't really a warranty item anyway, they're considered 'wear-and-tear', but Honda agreed discs should last much longer.
  4. NorthernClarity
    Thank you for the reply and information. It is really appreciated! Going to contact Honda Canada next week and see how it goes.
  5. Casey Martin
    Casey Martin Active Member
    Update!
    My rear outer pads were getting low and needed to be replaced. I also had a slight vibration while braking but not in the steering wheel which points to the rear rotors being warped. I am a fairly aggressive driver and I just broke 100k miles. I've never had brakes last this long. Regenerative braking definitely helps increase brake pad life. I replaced my rear rotors and pads this past Saturday. I used Evolution Geomet coated rotors and their Z17 ceramic pads from Rockauto.com. I also painted the calipers and caliper brackets silver. I live in RI and rust is something you have to deal with. I hate looking at rust. I have HR-V wheels with snow tires on now and you can easily see the caliper through them. With the stock wheels and covers installed you can't really see the caliper. I figured while I was doing the brakes I mine as well spend the time to paint them. Besides looking good it helps to slow down the rust as well. It looks nice freshly painted with new rotors installed. It will rust again soon enough but I think the couple extra hours of work is worth it.
    I still haven't replaced the front pads. I replaced the front rotors already as I mentioned earlier in this thread. I am going to replace the front pads fairly soon but I don't need to just yet. When I do I will paint the front calipers and brackets as well. I might replace the rotors again when I replace the pads since they are not very expensive. I could have them turned but that would probably cost more than replacing them nowadays. Plus the parts of the rotor that aren't touched by the pads are already starting to rust. That is the main reason why I might replace them again. Did I mention that I hate rust? ;)
    I attached a pic showing how it looks. Unfortunately it snowed last night so it is covered in salt. I will post a better pic after I go through the car wash.
    MrFixit likes this.
  6. MrFixit
    MrFixit Well-Known Member
    So, do you just paint over the rust on the calipers, or is there something you do to clean them up some before painting?
  8. Casey Martin
    I used a wire wheel on a drill and some wire brushes to clean the brackets and caliper the best I can. I put the brackets in a vice to do this. I didn't remove the calipers from the car. That would be ideal but that is a lot more work since it would require bleeding the brake lines. I do the best I can cleaning them and then tape off what I don't want to get paint on. I then clean them using brake cleaner and blow it off with compressed air. It would be best to then use sand paper and clean with mineral spirits or another type of degreaser but I am not looking for perfection. I do use brake caliper specific spray paint. I will post a pic of the can I used when I get home.
    Search on Youtube. You will find a ton of videos about this. If I was building a show car I would definitely do a better job. For a daily driver I am happy with the results with the steps above.
  9. Casey Martin
    I should mention that in order to replace the rear brake pads you have to deal with the electronic parking brake. The easiest solution is if you have access to a scan tool to put the rear brakes in "maintenance mode". When you put it in maintenance mode the electronic parking brake screws itself all the way in. Then you can compress the caliper piston easily using your typical brake tools or a pair of channel locks. There are other solutions that aren't quite as easy but can be done without a fancy scan tool. If you search on YT for changing Honda rear brake pads with an electronic parking brake you will find a ton of videos showing other options. The Clarity's rear brakes are similar to other Honda models with an electronic parking brake.
    moka likes this.
  10. Casey Martin
    Here is a pic of the can of spray paint I used on my rear calipers and caliper brackets.
