evse recommendations?
Discussion in 'Cooper SE' started by KeninFL, Jun 13, 2020.
  1. Lainey
    Lainey Well-Known Member
    It would be relatively close. Technically closer to 31A with the 7.4kwh they rated. We opted for a 50amp for up for 40 knowing other family members are getting EVs too. I have a ChargePoint that will be nice for the SE and most other cars that we'll get. I admit I did pass on the Siemens partially for that aspect, but also for size.
  3. GetOffYourGas
    My JuiceBox reports the Mini pulls 30.9A when charging. The EVSE can supply up to 32A. This lines up nicely with the sticker which claims a 7.4kW on-board charger.
    At 240V / 30.9A (7.4kW), assuming an efficiency of 90% (anyone have a better number?), it takes 4h20m to charge that 28.9kWh (usable) battery from empty to full.
    At 240V / 30A (7.2kW), it takes 4h28m to charge to full.
    That's only an 8 minute difference. Only charging from 50% to full? It's only 4 minutes.
    I wouldn't think twice about a 30A EVSE for this car.
    Lainey and insightman like this.
  4. Puppethead
    Puppethead Well-Known Member
    The electrical circuit does need to be sized for a load 20% higher than the max amperage draw of the EVSE. So to charge your SE at 30 amps would require a 37.5 amp circuit, which would get rounded up to a 40 amp breaker and wiring. That actually gives a max charge of 32 amps. The car will never draw more than it can handle, but if you have an EVSE that will allow more than 32 amps it should to be on a 50 amp circuit (or higher), or have a way to limit power draw. My Grizzl-E EVSE has internal DIP switches to set maximum draw.
  5. bldxyz
    bldxyz Well-Known Member
    That is exactly my style of analysis! Thank you.
    That makes me more flexible. I can decide to go with the Siemens or one than does 32A or greater since 4-8 minutes will hardly matter. Sure, maybe one day I haven't recharged it in awhile, and I unexpectedly need to charge it up, but if I'm not charging it overnight and I need to have a full charge the next day for any reason, I think I'll only have myself to blame, not the Siemens kit!
    Lainey likes this.
  6. Puppethead
    Another thing to consider is charging isn't linear. EVs slow down once they get above 80%-90% SoC to protect the batteries, so the draw can drop quite a bit. The SE, from all reports I've seen, does a really good job of charging near maximum until about 90%, then slows down. Although I've personally seen the DC fast charge slow down at 80%.
    But this drop-off will be the same for 30 amp or 32 amp, so it shouldn't make much difference except for the overall finish time for any EVSE.
    Lainey likes this.
  8. F14Scott
    F14Scott Well-Known Member
    For your outdoor 14-50 outlet, does code require a GFCI breaker? Your material cost seems low, if so. As I understand it, you can avoid the GFCI breaker only if you hard wire the EVSE, and perhaps then only if the EVSE is inside. But, code varies a lot from place to place.
  9. Puppethead
    I believe as of the 2010 (?) National Electrical Code even indoor outlets require a GFCI breaker. I was told it's code in my state which is why I hardwired my EVSE, since I can't find any EVSE manufacturers that don't build GFCI into their product.
    F14Scott likes this.
    I have a Lectron EVSE we are about to have Dominion Power (our provider) install smart meters in our area so I can take advantage of the low overnight rate.
    I really like charge and climate feature having the car preconditioned to my preferred temperature and charged in the morning is a great feature. I also have it set for my commute home from work I can hear the heat pump running as I approach the car and its the perfect temperature when I get in and set off home.
    Puppethead and GvilleGuy like this.
  11. Puppethead
    I do the same thing, which is brilliant in 10 ºF weather. I'm amused to see all the ICE cars in the lot running with their headlights on while warming up, and my SE sits there with no sign that it's climatizing unless you get close enough to hear it.
  13. GvilleGuy
    GvilleGuy Well-Known Member
    I got a few quotes from electricians to install my Chargepoint Home Flex EVSE. The one I scheduled cannot come until mid February, but that should still be WAY before I see my theoretical Mini (whose order is still waiting acceptance). The electricians I spoke with recommended hardwiring the Chargepoint because putting in a NEMA 14-50 outlet would require a GFCI outlet, and, as has been discussed here, even the Chargepoint installation manual recommends hard wiring to avoid false trips of a GFCI. I'm in South Carolina.
    My experience level with an EV is zero. So, just to make sure I have the somewhat confusing terms correct:
    (1) The level 2 EVSE I purchased comes with a J1772 plug, and this is the type of plug that, when available at a public charging station, will provide a complete charge in around 4 hours. (As well as the Chargepoint in my garage) Correct?
    (2) We have family 90 miles away from our house, so I was looking at available public charging stations in that area. I see four types listed:
    • J1772
    • CCS/SAE Combo: This is the DC fast charge type for the Mini which can normally get you from empty to 80% in 30 minutes?
    • CHAdeMO: The Mini does not use this standard, right?
    • Tesla: N/A
    The contents of the Chargepoint box: (and our cat, Oz)
    MiniSER likes this.
  14. F14Scott
    Everything you wrote is correct. You're smarter than you look!
    MiniSER and Texas22Step like this.
  15. GvilleGuy
    LOL - thanks!
    Texas22Step likes this.
  16. F14Scott
    Also, if there are Tesla "destination chargers" around (Level 2, 208 or 240 VAC Tesla *connectors*, usually found at hotels and stores), you could buy and use one of these. (I have one, both to use on the road to give me additional charging options and at home because I have a home Tesla wall connector.):
    https://www.amazon.com/dp/B07V7V2QT8/ref=cm_sw_r_cp_apa_fabc_i8gdGbD8PP4T0?_encoding=UTF8&psc=1
    Note: This will not work at Tesla Superchargers (DC Level 3 Tesla *chargers*, usually found in banks of 6 or more chargers at highway stops). It can't handle the 100Kw current and doesn't know what to do with the DC.
    GvilleGuy likes this.
  17. insightman
    There are two types of public Tesla chargers. The DCFC Tesla Superchargers that verify that the connected car is authorized to connect and charge (very quickly). Level 2 (AC) Tesla Destination Chargers are available to private establishments who want people to hang out at their establishments while they charge their Teslas. Unlike the Supercharger network, Tesla does not administer Destination Chargers.
    As I understand it, these Level 2 Destination Chargers do not check for authorization. Reinforcing that understanding are the available Tesla-to-J1772 adapters that enable non-Tesla vehicles to use Tesla Destination Chargers. That said, I've never seen a Tesla Destination Charger at any private establishment.
    F14Scott and GvilleGuy like this.
  18. F14Scott
    They're all over the place, here in Houston.
    BTW, Plugshare is a great app for finding the juice.
    GvilleGuy and MichaelC like this.
  19. Lainey
    This is my understanding of Destination chargers as well. We have a lot in our area - more than superchargers to be honest too.
    @GvilleGuy Hope all goes well with the installation. We used the same one for my garage and just moved the line and receptacle to the other side of the house. Only used it a few times, but works great from what I've seen.
  20. GvilleGuy
    That is the app I was using to look at stations in Columbia, SC. On the side of town where I would be staying, there are 9 CSS/SAE plugs:
    1) A Spinx gas station EVGO - 1 plug
    2) A Chevy dealer - 1 plug
    3) An Electrify America station at a Wal Mart - 7 plugs
    Looks like EA might be the best option.
  21. insightman
    I'm not surprised I've never seen one--I just checked PlugShare for local Tesla Destination Chargers and found there's one in an Ann Arbor parking structure and one at a Sheraton Hotel south of town for a total of 2 in a rather large area (carefully cropped to exclude Detroit, where there are a few more):
    GvilleGuy and F14Scott like this.
  22. Texas22Step
    Texas22Step Well-Known Member
    It may pay to shop around a little. The manufacturer of this item is currently (pun intended) offering it for $150 less 5% for new customers. Amazon has dropped the price to $160. I didn't search further, though.
  23. Texas22Step
    Here in the D/FW area, I rather frequently see these destination chargers at hotels that (I guess) want to attract travelers with Teslas to stay there overnight. FYI.
