Electrify America Chargers
Discussion in 'Hyundai Kona Electric' started by Esprit1st, Jun 23, 2019.
  1. wizziwig
    wizziwig Active Member
    Exactly. The throttle starts much earlier (under 60% SOC) unless you're using a slow 50 kWh charger in which case you're starting off already throttled so it's a moot discussion.
    Here is another graph that clearly illustrates the Kona throttle points:
    https://support.fastned.nl/hc/en-gb/articles/360001029367-Charging-with-a-Hyundai-KONA
    Kirk likes this.
  3. cmwade77
    cmwade77 Active Member
  4. hobbit
    hobbit Well-Known Member
    It occurs to me that if more people start towing with EVs, esp. on their long RV trips, that
    we're going to start needing pull-THRU rapid charger bays. Some owners might otherwise
    need to drop the trailer just to get situated properly. Extension cables probably wouldn't
    help, and I doubt anyone makes a viable CCS extender anyways.
    Some of the installations in the EU seem to be sort of a pull-thru architecture but designed
    to accomodate multiple standard-length vehicles at once, not intended for a full rig
    taking up all the space while other drivers wait.
    _H*
    Fastnf likes this.
  5. ericy
    ericy Well-Known Member
    The Tesla people have already been down this road. Some of the newer SC have a spot designed for pull-through.
    Even with my Kona, getting into an EA charger is sometimes difficult given how short some of the cables are.
  6. echeck
    echeck New Member
    EA isn’t offering free charging for some reason, are they? I ask because the last two times I’ve used their nearby charger it has just started juicing up for free. I plug in, and it starts charging.
    If this is a charger error then you didn’t hear it from me! Ha ha
  8. If you don't own an ID.4 than perhaps it is wise to enjoy the new (favorable) rates while you can;)
    mho likes this.
  9. echeck
    echeck New Member
    Ha ha! Nope. 2019 Kona.
    Anyone in the Columbia, MD area, hit up Walmart for a free charge! ..unless they've fixed it by now.:D
  10. cmwade77
    Yeah, I agree, that would be a favorable rate.....LOL
  11. echeck
    echeck New Member
    Turns out the favorable rate was intentional!
    Pulled up to the same charger again yesterday and it had this message displayed:
    “All sessions at this charger will be complimentary. This is a temporary measure while we work to remove equipment and install new chargers.”
    The only thing better than a free charge is a GUILT FREE free charge. Ha ha
    cmwade77 likes this.
  13. cmwade77
    That is awesome, wish they would do that around here
  14. TRSmith
    TRSmith Member
    Was it also throttled to 50 kWh? I heard that would be their usual procedure during the replacement process.
  15. echeck
    echeck New Member
    Nope, it was full speed with the normal incremental slowdowns.
  16. echeck
    echeck New Member
    The free ride has come to an end.. Drove by yesterday to the same place to charge up, and it’s all fenced off.. It was good while it lasted! :D
    I’m really curious as to what they’re doing that they need to replace actual hardware. Whatever it is they better hurry up, because I’ll have to use EVgo until they come back online. I don’t care for EVgo.
  17. TRSmith
    TRSmith Member
    EA's replacing a bunch of chargers, mainly along the East Coast, mainly over quality issues. I believe the bad chargers were made by Efacec, and most of the replacements are Signet.
    I'd check out the BGE chargers nearby at the Ascend One building, which is practically right behind Walmart. On Greenlots. More info: https://www.plugshare.com/location/248564
  18. Joev, Ginginova and Esprit1st like this.
  19. electriceddy likes this.
  20. ITown
    ITown Active Member
  21. Free charging is great, as long as you CAN charge. Here is an experience I wish nobody will ever have:
    arhnold likes this.
  22. hobbit
    Does the app depend on having its own solid data connection via cell? It may have gotten out
    of sync just because it couldn't talk to EA when it needed to. A more remote possibility is
    spotty connectivity to the charger installation, unless that's hardwired to a local provider.
    Yet more evidence for how stupid EA's dependency on the app is. If they'd just implemented
    tap-cards like most other networks this would have been so much easier. No app, no phone
    connectivity issues. No app-store that requires its own account just to download something
    that's supposed to be public. Ability to participate in the network interoperability that seems
    to be developing.
    _H*
    Kirk, Esprit1st and electriceddy like this.
