Difficult to access heated seats
Discussion in 'Hyundai Ioniq 5' started by BobS, Nov 18, 2022.
  1. BobS
    BobS Active Member
    On most cars you can push one button to turn on the heated seats. In the ionic 5 you first have to touch the climate control then the front warmer control, then finally touch the heated seat control. It would be convenient if there was a way to set up a shortcut to take you directly to the heated seats.
    Same goes for the heated steering wheel.
  2. P&T
    P&T New Member
    I’m one of the rare souls that purchased a plain RWD SE, but the SE does have a haptic “button” labeled “warmer” on the HVAC controls that I can use to get directly to seat heaters.
  3. MJ53
    MJ53 New Member
    New software update enables voice command to control heated seats and steering wheel.
  4. BobS
    BobS Active Member
    Is the new software available ?
  5. BobS
    BobS Active Member
    Just tried it and you can do it thru voice commands.
    1stEV likes this.
  6. MJ53
    MJ53 New Member
    Apparently it was out at the end of Oct but retracted on Nov 2nd for some unknown reason. Waiting for it to be rereleased again.
  7. BobS
    BobS Active Member
    It works unless I have my phone with me then it connects to Siri, and she says I can't do that. How do I connect to the car voice command when I have my phone with me?
  8. MJ53
    MJ53 New Member
    I haven’t tried it myself yet but I believe if you just use a short button push instead of the long one to connect to Siri, that should work.
    1stEV and BobS like this.
  9. BobS
    BobS Active Member
    Hooray!! That's it, a short press gets voice commands for the car a long press gets you to Siri.
    Thank you
  10. Totally convenient but I guess Hyundai wants the ability to upcharge you for a GV60 to get that common sense functionality of an actual button for heated/cooled seating and heated steering. :(
  11. David McMaster
    David McMaster New Member
    This would matter less if the heated wheel/seats remembered their status when the car was shut off and back on. I don't really know if it does. Does it?
  12. MJ53
    MJ53 New Member
    Nope. Unfortunately it is default set to level 3 each time you initially turn it on. If you use voice commands you have to say “ turn on seat warmer” first and a separate command to say “ seat warmer level 1 ( or 2)”. Same thing with the passenger seat.
    I would like to think this could be fixed with a software update in the future if enough people brought it to their attention.
    1stEV likes this.
