If one buckles one seatbelt and leaves the other unbuckled, it does give a Christmasy look to the panel. Just something else to ignore. Between the lane change icon, the braking icon, and the speed limit, I have enough to look at. The front passenger seatbelt warning is entirely something else. I put a frozen turkey in the passenger seat, and the damn car yelled at me all the way home.
Yes! I have my 14yo who rides in the back when the three of us are in the car (about once a week, and yes a 5'8" guy fits fine back there) so the panel is red and green. Kinda funny really. Threw my spouse when he first saw it. Gallons of milk will set my alarm off for the seat belt. I always remember to buckle in now if i have one there
Nice! Well maybe I'll have to just buckle one side to get that affect. Might help brighten my morning while I wait for the light to go off for the first couple minutes of my drive
I've been having a lot of fun playing around with settings in Bimmercode. Thanks for the tips here on keeping the pedestrian sound off. I found one setting isn't able to work on my car, the "Rolls Royce" warning chime. For me, it makes the same sound as the "BMW" chime. Has anyone been able to enable that chime?
Some adapters are on sale Some adapters may experience Bluetooth failure during coding Some adapters are exclusively for iPhone/Android Some adapters also work for different vehicle brands/apps There is also a weak correlation for adapters on sale and Bluetooth failure during coding requiring Esys.
@Joe c overcame his problems with Bluetooth unreliability using an ENET cable connected to a computer running Bimmercode while the Bimmercode wizard was controlling that computer remotely. So would an ENET (ethernet-to-OBDII) cable with a Lightning adapter for the iPhone be better than any Bluetooth adapter? Here's such a package for $30 on Amazon. If you were running Bimmercode on a PC with an ethernet port, all you would need would be an ENET cable, which Amazon sells for $15.60:
Just received this cable from AliExpress, about $7 delivered https://www.aliexpress.com/item/4000872738532.html Also this https://www.aliexpress.com/item/1005003737238469.html
Actually it was using an ENET cable connected to a computer running ESYS. Bimmercode is mobile only - iOS or Android. But yes, if at all possible, always code using a cabled connection rather than bluetooth.
+1 for hardwired. It’s much faster than wireless and less prone to dropouts. You still need to make sure your device doesn’t turn off, but it’s so quick that it isn’t really an issue.
My post above has the links to the cable and lightning connector needed to connect directly to an iPhone/iPad (iOS).
Dumb question, but I still need a bimmercode supported OBD adapter right? which one do you recommend with this setup?
Don't have my car yet! so haven't tried it out, but my understanding is that the cable (the black bit on the end of the yellow cable) plugs straight into the port. That is the adapter.
Are you sure this will work? I have my doubts the App was developed to allow for a direction connection like this. Did you check with Bimmercode to confirm that your setup will allow you to connect to the car?
Yes it works, it's directly supported by the Bimmercode app - it's also how I and various others have coded our SE's. I use a different Ethernet to Lightning adapter than that one, but the concept is still the same.
I haven't had any issues coding over bluetooth with the veepeak adapter, but y'all have scared me enough to order the aliexpress wired reader and lightning adapter.
