chargers and charging rates
Discussion in 'Bolt EV' started by Tim2, Oct 16, 2019.
  1. Tim2
    Tim2 New Member
    Hello everyone. I've got 2 questions:
    1. Which portable level 2 chargers should I consider buying, and which should I avoid?
    2. When charging at level 1, you can choose either 8 amps or 12 amps. Can you also choose the amperage when charging at level 2? I'm not asking whether I can buy either a 16 amp charger or a 32 amp charger, because I already know I can. I'm asking whether the level 2 charge rate is adjustable on the Bolt's charging screen like it is on level 1, or whether some chargers will allow you to switch between 16 and 32 amps.
    Thanks very much.
  3. DW'sGen2
    DW'sGen2 New Member
    Charge rate can only be changed from 8 to 12 amps for level 1 charging.
  4. DW'sGen2
    DW'sGen2 New Member
    Aah, no changes in charge rate for level 2 charging can be performed.
