Discussion in 'Clarity' started by MrFixit, Feb 27, 2021.
  1. Agzand
    Agzand Active Member
    I think driving pattern has some impact on degradation as well. If you are doing a 40 mile highway run after each charge that is a 2C discharge rate twice a day. If you are mostly city driving that is closer to 1C discharge and much easier on battery.
  3. MrFixit
    MrFixit Well-Known Member
    1. Regarding the sensors - We provided the sensors to the Car Scanner developer (which he incorporated), so when you choose the Clarity profile, you get those. Before Car Scanner adopted our sensors, we were posting them in a form that could be imported. You should use one or the other (not both), so either import the sensors from our files, or choose the Clarity profile. There is only a subtle difference - we added a few sensors (maybe 3 or 4) and never bothered to send an update to Car Scanner so there are a few more in the posted ones.
    My advise is to just use the Car Scanner profile, and don't bother with the posted ones. The few extra are not especially useful, and using the built-in profile is easy. If you inported them and have double, just go in and delete all the custom PID's and I think the doubles will go away.
    2. Location in the spreadsheet? Just do whatever makes sense to you. We have no formality or specific purpose for the location field. You could add a note if you like that states your actual scenario.
    Thanks for joining us in this quest for knowledge !!
  4. MrFixit
    Happy New Year, and thanks to everyone for their interest in helping to characterize the HV battery longevity of this great vehicle !!
    Thanks to all, we have accumulated a wealth of information.
    Don't forget to check out the results of this ongoing effort by examining the shared spreadsheet.
    This is my favorite plot:
    https://docs.google.com/spreadsheets/d/1LHtqVuPzHUDXmX1jiHOQIpT_YiGp9N-vnBOiSz96C2I/edit#gid=1735681880
    The Introduction Page has instructions and links to data entry and all of the graphical results:
    https://docs.google.com/spreadsheets/d/1LHtqVuPzHUDXmX1jiHOQIpT_YiGp9N-vnBOiSz96C2I/edit#gid=1710145002
    If you are already a participant, but haven't done a measurement for a while,
    the start of 2022 is a great time to pull out the OBD tool and add a fresh new reading to the data set !!!
  5. Rachel Sherman
    Rachel Sherman New Member
    Hi all, this might be a long shot, but I noticed some of you are in Maryland. I'm looking at buying a 2018 Clarity in Baltimore, MD, and asked the dealer (not a Honda dealer, unfortunately just a general used car dealer) to do a battery capacity test, as I want to make sure it's still functioning well before buying. They said they will not do them, as they are not a Honda dealer, but that I could bring in my own OBDII scanner -- which is when I found this forum. I can order the Vgate iCar scanner, but it won't be delivered for about a week. Any chance someone in Maryland is near Baltimore would be willing to loan theirs?
  6. MrFixit
    @Rachel Sherman -
    I am in the general Baltimore area. Let's discuss.
    I sent you a PM.
  8. insightman
    You certainly lucked out if @MrFixit lives close enough to help! He can probably get even a reading on how many cigarettes were smoked inside this Clarity and how long the power-drill was connected to reverse the odometer.
  9. MrFixit
  10. Sergi
    Sergi New Member
    Hi everybody! I just got my Clarity and one of the first things I've done was checking the battery capacity. I set up Torque like the Original Posting, but the reading I am getting is 491.5ah. From what I see on the forum, I would expect that to be 49ah assuming it's just the decimal placing that is wrong, but it makes me wonder if there is more to it. Any clues?
  11. MrFixit
    This thread has become pretty cluttered. The easiest way to get started is first insure that you have the compatible OBD2 adapter, then just select the Clarity in Torque Pro. We provided Torque Pro with all the necessary PID's and it is no longer necessary to define anything on your own. The scaling should be right, and you should see a number in the 40-something amp-hour range.
  13. JFon101231
    JFon101231 Active Member
    I'll have to try again myself. I bought the right plug in but quickly got lost after that and gave up ‍♂️
  14. JohnT
    JohnT Active Member
    Hi Mr Fix-it... I missed the info on Torque Pro and Clarity... I have not been able to find the Clarity in the program :-(
  15. MrFixit
    @JFon101231 , @JohnT , @Sergi
    I APOLOGIZE for the brain freeze...
    You MUST use "Car Scanner" to obtain the Clarity parameters. Torque Pro has a fundamental problem with the long messages.
    Madmartigen and Sergi like this.
  16. Ohliuw
    Ohliuw Active Member
    was there another thread for the the readouts? My spring readings at 52250 are : 418DC41D-319B-454A-BB76-43DABDB696C5.jpeg
  17. MrFixit
    This is where everyone has been entering shared battery data:
    If you are not spreadsheet literate, let me know and I can enter your information for you. There are a few other questions like model year, estimate of percentage EV driving, state you are located in, level 1 vs level 2 charging, etc.
  18. Jamchow175
    Jamchow175 New Member
    I can't seem to figure out how to check capacity. I have the scanner and downloaded Car Scanner and paid for the premium version. The amp-hour does not show up.
    I uploaded a screenshot. I'm getting terrible range 27 on a full charge. Empty battery to full charge only taking 11.4 Kwh. It doesn't seem right.
    Local Honda dealer wants to charge 180 to check capacity and admitted they don't know much about the hybrids. I said no thanks.
    Any help is appreciated. Screenshot 2022-05-16 at 3.10.30 PM.jpg IMG_1173.jpg IMG_4767.jpg
  19. MrFixit
    Good for you... $180 to check capacity is outrageous. It is literally a 5 minute job.
    You are showing the correct screen on Car Scanner. Please elaborate on precisely which OBD adapter you are using. My suspicion is that you have a device with limited buffer size and that's why the reading isn't available. With a little more information I am certain we can get a reading for you.
    I assume your 11.4 kWh is for a 'full' charge (from zero EV range)? Do you have a history of multiple full charge readings?
    As an example, a full charge on my Clarity is typically around 12.5 kWh. This yields an EV range of around 50 miles (in the summer, with my driving particulars).
    What is your history with this car? Is it new for you? Range is highly dependent on how / where you drive. Tell us a little more about your driving scenario. 11.4 kWh is not especially bad. You should get a range greater than 27 but you can't draw a conclusion on a single measurement, and your driving scenario is critically important.
    You will also find a lot of controversy about the EV range estimate. People refer to it as the Guess-O-Meter (GOM). It predicts the range based on recent drives, and if your current drive is substantially different than your recent history, the GOM will do a poor job. Pay attention to the actual miles you get, an not just the reading on the GOM.
  20. Jamchow175
    This is the adapter I am using. It's one of the more expensive ones so I was hoping it was a good one.
    https://www.amazon.com/gp/product/B076XVQMVS/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
    The car was purchased new in 2018. Originally had about 40-42 miles range.
    We live in southern CA so it's hills everywhere we go and freeway 70-80 mph with traffic.
    We have monitored actual miles traveled and EV range estimates. It's been pretty close +/- 2-3 miles depending on hills and terrain.
  21. MrFixit
    @Jamchow175 ,
    It is highly likely that your adapter is not capable of reading the larger messages provided by the Clarity.
    More expensive definitely does not mean better...
    I would consider it a waste of time, but if you really wanted to be certain about your adapter, you can try the test that is shown in an earlier post in this same thread here - https://www.insideevsforum.com/community/index.php?threads/budget-battery-capacity-readout.10531/page-2#post-123944
    Do this test, and send a screenshot of the result that you get....
    My best suggestion is to purchase the tried and true adapter that we have proven to be good (and most everyone here is using). This post shows specifically what to look for when purchasing one. They are only around $30:
    https://www.insideevsforum.com/community/index.php?threads/pc-based-electric-powertrain-report-battery-capacity.12220/#post-148549
    If / when you get a capacity reading it will be interesting to see if the capacity reflects the actual drop that you seem to be seeing. If your numbers accurately reflect a true change in capacity, then 41 miles dropping to 27 represents a 35% drop from your original capacity. I believe your 'full charge' of 11.4 kWh only suggests maybe a ~20% drop.
    One more thought that you can try as a "Hail Mary" is to disconnect the 12V battery for a few minutes. This is sort of like a hard reboot and it could clear out some software malfunction affecting performance or the GOM... NOTE - after doing this, you will see a LOT of ominous errors / failures when you start again. They should all clear out after driving a few miles. It will take several drives / recharges for the EV range reading to settle again. This seems unlikely to me, but may be worth a try if you exhaust other possibilities.
    I recommend that the capacity reading is the best first step.
  22. Jamchow175
    It looks like you are right. I used a different adapter and got a reading, 43.64 AH.
    It looks like mine has mine has degraded quite a bit more than the other posters at 72,000 miles.
    I charge level 2 as much as I can and do about 80% EV with occasional long trips with gas.
    Does anyone know if someone has had a battery pack replaced for degradation?
    I'm in California and had 15/ 150,000 warranty so hopefully, I get a new battery before it runs out.
  23. MrFixit
    There have been maybe 4 or 5 battery replacements reported in this forum. I don't believe any of these have been due to loss of capacity. One battery was called back by Honda (it was fairly early on, and the owner wasn't having any problems). It seemed like Honda may have observed something via telemetry and they wanted to investigate. Any others that I can think of were outright failures, seemingly due to other components within the battery pack such as the inverter, etc.
    Your capacity of 43.64 is down about 20% (and consistent with your full charge energy input). A capacity 'failure' is a loss of 33.3% (1/3 of the original capacity). If your original range was ~41 miles, then a 20% drop should still give you a range closer to 32. With a lot of hills and 70-80 mph, you are pushing the Clarity and I'm sure that's why your range is less than many of us.
    We are all very interested in battery longevity of course, and that's why we are doing this characterization. I was thinking that degradation would not be linear and would level out over time. I am not sure we are seeing that yet. I put your reading into the spreadsheet as best I could. Please feel free to add any additional information and assist us by contributing going forward !
    I wouldn't bank on scoring a replacement battery... I don't believe your degradation is 'quite a bit more than other posters at 72K' at all. We don't have a lot of users yet with that many miles to draw a conclusion from.
