Anyone install any Apps on the Clarity?
Discussion in 'Clarity' started by StickWare, Jul 26, 2018.
  1. Tdude
    Tdude New Member
    i tried but once the system detect the apk file on USB, the 'Install button' on pop-up is greyed out.
  2. weave
    weave Active Member
    Now I know I can go back I may play with it some more.
    Why do you like it better? Are you able to customize what's on that screen and arrangement?
  3. Tdude
    Tdude New Member
    lot more options at your finger tip then the default screen. also the visual is better (IMO)
    weave likes this.
  4. tdiman
    tdiman Member
    There is a white list file that has approved apks in it. Editing the whitelist and installing apps is 80% of what Honda hack does.
  5. insightman
    Is it known what apks are on Honda's white list? In other words, can the hack(er) reveal the list or can the hack only clobber whatever list Honda installs in the system?
  6. StickWare
    StickWare Active Member
    That's exactly what I was doing.
  7. StickWare
    UPDATE:
    Even though the tablet and Google Maps through Android Auto was working, it was annoying to have to connect via bluetooth every time I got in car.
    I decided to try the Honda Hack. Quick and easy and I got Google Maps and Waze installed. I also installed the YouTube app, NetFlix and even MLB.At Bat. Seems to be working well, and this version of Google Maps is much better than what went through Android Auto.
  8. StickWare
    I even installed CrossyRoad, just to see if I could. I could, but I don't think it runs right. It says it needs Google Play which in unavailable on your device.
  9. JJim
    JJim Active Member
    Awesome. Are you be able to use Google Maps offline (download maps and store it into the headunit)?
  10. Odobo
    Odobo Active Member
    Can you install vlc as well? I wanna see if I can play some Disney for my kid XD
  11. StickWare
    I spoke too soon. Many problems. I’m going to Uber in a bit. Major issue is Apple CarPlay doesn’t work. Read this is an issue and there is a way to turn it on briefly but doesn’t work if you shut car off
    So I’m running phone , Bluetooth to car playing music. Every time Google maps talks, it kills my Bluetooth source for audio.
    Maps is slow too. Will play more.
    Don’t know what van is.
  12. StickWare
    Anyone know how to exit developer mode??? That might be the problem?
  13. Odobo
    Odobo Active Member
    There should be a toggle on top after you enter the developer page, you can turn it off there.
    Get a android :p mine works seemlessly and don't need Bluetooth to stream music.... Map talks also don't kill music too!
  14. weave
    weave Active Member
    Is there a way to reset to factory image to get everything back to normal -- as sort of a last resort?
  15. StickWare
    The toggle there doesn’t actually shut off developer mode. It just shuts off the developer options. But it still says I’m a developer.
    I might have to do a hard reset. I can’t get Android Auto to work for nothing now. :(
    ddddcsd likes this.
  16. tdiman
    tdiman Member
    Go into Honda hack and use fix problems button. Then reboot your head unit.
    I don't recommend installing anything that isn't offered in Honda hack app store. People screw up their head units and end up going to Honda.
    There is now a service bulletin specifically on Honda hack, so they may start cracking down on people.
  17. StickWare
    Where is this fix problems button??
  18. Alantn
    Alantn Member
    The whitelist.xml file is located at data/system/whitelist.xml
    Make sure you enable the ROOT Explorer option in ESexplorer so it can access system files.
    [Menu>Tools>Root Explorer>switch on]
  19. StickWare
    Sorry. The fix problems options are in pro version
    I have no idea what you are talking about. I don’t know what ESExplorer is or where the menu is you are referring to. Thanks.
  20. Alantn
    Alantn Member
    ESExplorer is one of the file managers on Android with root option for you to view/edit any files. I was referring to @insightman 's question regarding the whitelist of apk files that you can install.
