Any outlook for large batteries (more range) for future Mini's?
Discussion in 'Cooper SE' started by The Dark Side, Sep 16, 2021.
  1. insightman
    Yes, on this forum one should always be specific: "Mini" vs "MINI"
  3. CuriousGeorge
    I was referring to the first generation MINI (R50/52/53). Prior Minis were obviously even smaller.
    IOW, the MINI has grown significantly larger under BMW's 21 y stewardship, with this SE prototype apparently being an attempt to reverse this trend.
  4. insightman
    My SE is the largest car I've owned since my 1978 Mazda RX-7. I'm OK with the SE's current size or a newer, smaller size, but I won't switch unless MINI adds lightness and doesn't subtract power.
    F14Scott, GetOffYourGas and GvilleGuy like this.
  5. CuriousGeorge
    Ideally, power:weight remains unchanged. But, we each have our needs/wants/desires (I'd like 150 mi range under worst-case conditions, so I could visit my kid at college w/o having to recharge).
    GvilleGuy likes this.
  6. Puppethead
    Puppethead Well-Known Member
    If the new one has the same amount of battery, shouldn't it be lighter than the SE with the elimination of all that front end frame? I don't know how MINI is shrinking down the electric motor and heat pump for the smaller space, though. If they drop the heat pump that would be a dealbreaker for me, since I live in the far north.
  8. GvilleGuy
    GvilleGuy Well-Known Member
    I would want interior to stay the same - and I'd be okay with the exterior shrinking only if crash protection ratings would remain adequate.
  9. Puppethead
    BMW's new i4 M50 is interesting, maybe foreshadowing the future for MINI? In particular, motor and battery improvement.
    "The [drive] units are compact and have a 50 percent higher power density than the drive unit in the i3. Being electrically excited, they eschew the use of rare earth materials in their construction. BMW says the motors have an efficiency of 93 percent."
    "The 4.3-inch (110-mm)-tall prismatic cells supplied by CATL and Samsung SDI have a 40 percent higher volumetric energy density than the cells in the outgoing BMW i3."
  10. Puppethead
  11. insightman
  13. CuriousGeorge
    Reviewing this thread, I'm disappointed that no one seems to have caught my pun.
