85 mile commute (round trip)
Discussion in 'Cooper SE' started by The Dark Side, Sep 12, 2021.
  1. The Dark Side
    The Dark Side New Member
    I sold my the wife's Audi TT (tired of endless CEL's on that thing) and am considering a Mini SE as a replacement. Her commute is about 85 miles round trip. Almost all highway. Would the distance be a concern to you if you could not plug in at work?
    Cheers,
    TDS
  3. chrunck
    chrunck Well-Known Member
    Where do you live? If you live somewhere with harsh winters it might be tight, but otherwise you're probably gtg, assuming you can fully charge overnight.
    Todd Swift likes this.
  4. The Dark Side
    southern Pennsylvania
  5. Puppethead
    Puppethead Well-Known Member
    That's exactly my commute, no charging at work. Driving in Mid mode, during warm months I have over 45% SoC left by the time I get home, and in winter I have over 30% SoC. Only in extreme cold (colder than -10 ºF) do I have to closely watch my range, but I still got home with about 15-20% SoC. These values are dependent on the types of wheels and driving style. For reference I have Power Spoke wheels in the summer and Spectre Grey Revolite wheels in the winter.
    There are a few tricks I rely on in the winter:
    1. Use the navigation map to select a "green" route that avoids the freeway. It'll take longer but use less battery, usually 10-20%
    2. Go into Green+ mode, which shuts off the heater and will give you an extra 15-20 miles range
    3. If possible, locate a fast charger along the commute and use that as a backup solution to add a bit of range on the commute
    4. Find a place with level 2 charging at lunch; even 30 minutes can add 10-15 miles range
    5. As a last resort use an ICE vehicle for extremely cold days.
  6. F14Scott
    F14Scott Well-Known Member
    Also, on the coldest days, starting from a partially warmed garage (so the battery temperature is 30 vice 0) will give you a substantially better outbound leg.
    GvilleGuy likes this.
  8. Puppethead
    I learned that on my road trip in -25 ºF weather. Left the SE parked/unplugged overnight at the hotel. The SE started and drove fine, but when I got to the DC fast charger nearby it took about 15 minutes of charging energy to warm the battery before it would start charging. Lesson learned: try to avoid sitting in sub-zero temps unplugged.
    MichaelC and F14Scott like this.
  9. F14Scott
    I know, right? Here in Houston, it's only mid-September, and already the nighttime temperatures are dipping into the low 90s...
    insightman, MichaelC and Puppethead like this.
  10. The Dark Side
    thanks for the info. We have a F250 she can drive in bad conditions.
  11. polyphonic
    polyphonic Well-Known Member
    To @Puppethead's point about fast chargers, you can check Plugshare to find 50+ kW fast chargers. If you get in a jam, even 10 minutes could add lot of range. The car does an 80% fast charge in 30-35 minutes, and doesn't taper that much to 100%.
  13. Jim In Tucson
    I would also suggest she explore a simple Level 1 plugin at work. It won’t give her a full charge, but would give her some, and it would keep the battery warm.
  14. Puppethead
    I don't think cold weather will be much of an issue in southern Pennsylvania. Looks like it doesn't get much below freezing. I found the SE performs great down to about 40 ºF, below which the heat pump loses its effectiveness. But even around freezing the batteries shouldn't get too cold.
  15. GetOffYourGas
    The heat pump works pretty well down to maybe 25F. At around freezing, you still have about 100 miles of range.
  16. insightman
    I keep wondering if data from the OBDII port can tell when the heat-pump hand-off to the resistance heater takes place. Not being an OBDII wizard like some on the Inside EVs Clarity forum, I'll have to keep wondering.
    GetOffYourGas likes this.
  17. GetOffYourGas
    I based that statement on my observations of efficiency and not OBDII info. The latter would be a much better source. But I can still get very good efficiency (3.5-4 miles/kWh) down to about 25F. Below that, it seems like the resistance heater kicks on because my efficiency drops quickly.
  18. Caconym
    Caconym Member
    Hello! I was very happy to stumble across @Puppethead 's experience with commuting in the winter. The post removed my last bits of anxiety about placing my order for a BRG/white SE (last week!). I have a 66 mile round trip commute in Vermont of about 80/20 interstate/mountain roads with a decent amount of elevation change. I've got my Bernie mittens, and had planned on relying on the heated seats in the winter, but sounds like I may be able to luxuriate in a little HVAC once in a while.
    joshf2k, Puppethead and insightman like this.
  19. insightman
    Welcome to the forum! I drove two gen-1 Insights like the one in your photo between 2000 and 2019. You'll never go 800 miles on a charge in your SE, but you're going to have a ton of fun. We'll be looking forward to tales of your Vermont commute.
  20. Caconym
    Caconym Member
    Thanks! It's great to see how much everyone is enjoying their Minis. Funny story about the insight. I grew up in Ann Arbor and spent a couple of years after high school working at Car and Driver magazine when the 1st gen came out. I was actually in the passenger seat for this crazy 130mpg drive from Dayton to Detroit: https://www.caranddriver.com/reviews/a15141105/how-we-won-the-insight-fuel-economy-challenge-without-cheating-much-road-test/ Almost 20 years later I found the one in the pic used with 240k on the odometer and drove it for another 40k before it died. Great car!
    Teddydogno1 and insightman like this.
  21. Puppethead
    I'm happy that my experience has helped!
  22. Teddydogno1
    Teddydogno1 Active Member
    Cool story. Interesting that the nearly 22-year-old article is still online.
    Rob
    Caconym likes this.
