2019 Kona EV Motor Noise Issue
Discussion in 'Hyundai Kona Electric' started by Mdsweb, Sep 24, 2021.
  1. Reduction gear lubrication replacement is scheduled for 120,000km in my manual!
    navguy12 likes this.
  3. Same. Could just be chance...keeping an eye on it.
    Sent from my SM-G960W using Tapatalk
    Wildeyed likes this.
  4. From what I understand, this was updated direction from Hyundai. It was just supposed to be an inspection but it was dirty so it needed to be replaced. When I check the Hyundai website it says 30 month check as well for my 2019.[​IMG]
  5. That's weird. I literally am looking at the maintenance schedule on the Hyundai website for a 2019 Kona EV and it not only doesn't mention the reduction gear until 120,000km it doesn't even HAVE the 30 month interval that yours is showing!! What the what??
    Edit* wait, it does say inspect at 60k.
    So it was 120k originally and now it's 30 months? And at 30 months I have only 35k kilometres but I might need a fluid replacement? That's a pretty big revision. And one that's potentially 4x more expensive. What did they charge you? I'd heard it's about $150.
  6. I understand "inspect" to mean check the level. Perhaps a diligent technician took a sample as well?
  8. Yes but it seems that these "inspections" are leading to the discovery of goop and goop is leading to (potential) fluid changes and at a rate 2, 3 or 4 times more frequently than originally suggested.
  9. Ginginova
    Ginginova Active Member
    I suspect that only first early reduction fluid change is recommended due to break in period generating more metallic debris.
    And all subsequent changes are most likely good to be done on normal schedule.
  10. I wonder how "updated" and I assume you mean "directive"? Perhaps they're finally waking up to all these gearbox failures?
    navguy12, electriceddy and Wildeyed like this.
  11. Ginginova
    There was always a fine print in Europe if car is driven in severe conditions that maintenance intervals for some of the items can be halved.
  13. No doubt there is a "severe conditions" schedule in all markets, e.g. below is from the manual on the corporate site.
    navguy12 and Ginginova like this.
  14. My copy of the Canadian manual says that the maintenance cycle defaults to "severe conditions" so any tightening of service intervals would be even more severe. It's feeling like a bait and switch situation.
  15. "Goop" is not really what you'd find with a small sample, noting how it appears clear but darkish while draining in the post #24 video. But when placed in a clear bottle the discolouration is obvious. Every Kona's gearbox oil will look at least as bad as this after 20,000 km. This one shown at 40,000 km is horrific, frame grab below.
    I'm all for scientific evidence-based conclusions rather than speculation, but ignoring that for a moment in the interest of expediency, I'm starting to think that this is the cause of the gearbox noise issues - conveniently the subject of this thread and multiple others. From a statistical perspective I'd have to image the chances of having two major design screw-ups so close together would be rare, so it may be just this one issue alone, the omission of a magnet.
    I can see how added bearing drag due to ingesting break-in wear particles could result in outer race spin and subsequent wear of it's aluminium housing resulting in loading the motor splines, making a clunking noise and wearing them. It's all entirely plausible. I've suggested to those in our local FB group (in NZ) that their oil should be changed at the first service at their own expense.
  16. Hyundai would have to acknowledge a problem for that to happen. Easier to simply amend the service interval and transfer responsibility to the owner.
    navguy12 and electriceddy like this.
  17. Back to "free oil change" manufacture incentives we go:D
  18. Yes, the irony was not lost on me …
    Oh, I thought I’d mention that a local Ioniq owner has had their gearbox fail at 75,000 km. I think it’s the same design we have. Out of warranty, Hyundai agreed to supply the parts, customer paid for labour.
    Of course no one knows if the oil was dirty because no one thinks to check.
  19. navguy12
    navguy12 Well-Known Member
    Thanks for the great research.
    Did you use the Hyundai fluids or the Redline product?
    If you used the Redline product, could you provide a link to same?
    Amazon (Canada) is not giving me the 70w GL - 4 options.
    Cheers.
  20. Use the Redline since you can get it. I think Walmart gave me a ship-it-here price. More realistically:
  21. navguy12
    Thanks for the tip.
    I have a short trip into Michigan (assuming no covid issues) next weekend and may be able to source the Redline over the counter at “Advance Auto”.
    I am waiting for a call back from my local dealership parts department regarding the cost of the Hyundai 70w GL-4 as well as the magnetic drain plug 00810 17121.
  22. I'll be interested to hear if they can provide that.
  23. navguy12
    The fluid is available over the counter, but at $54 (plus HST) a litre, I’ll wait and see what my trip to MI next weekend gives me.
    The magnetic plug: $CAD 4.56 (plus HST). Matching gasket: $CAD 0.56 (plus HST).
    For $5.79 (all in), I went ahead and ordered them ;)
    Should arrive at the local dealer by Friday morning.
    Esprit1st and electriceddy like this.
