KentuckyKen
This is roughly the plan I have too. I'm waiting for the electrician to call to get this started. I learned propane tanks can be filled even when the source of the propane does not have electric power. I like the idea of using propane that can be stored indefinitely. I only need about 3,500 watts. I don't want to oversize which would use more fuel.
All I want to do is power the refrigerator (surge 1,200w), a few lights, the garage door opener, and perhaps a one room electric 1500w space heater if the temperature drops too far.
I'm reading this thread because someone mentioned you're not supposed to charge a plug-in car with a generator. Does anyone know if Honda has that restriction? The power should be clean coming out of an inverter/generator. I doubt if I'd try to charge the car with a generator but I'd just like to know if it is acceptable. Should be able to fully charge a Clarity in about 4-5 hours depending on the size of the generator.
Wouldn’t it be more efficient cost and energy wise to just run the Clarity on gas instead of charging from generator power during a blackout?
Also check our Sams Club. Mine has a smaller dual fuel generator but it wasn’t a pure sine wave inverter type.
Champion brand 3,500 Watt for $350, wheel kit extra. Got good reviews.
