Maximum Range on Battery -- Comments
  • Thread starter Thread starter Timothy
  • Replies Replies 65
  • Views Views 13K
I am careful to never go over three lines when accelerating and mostly try to only use two. I use the paddles for full regen and only brake at the very end to being the car to a full stop. The streets I drive are 30-45 mpg speed limits with some school zones in the morning. I’m smashing the EPA estimate of 117 MPGe city the gas fill up shown took into account the charge that was drawn down in HV mode. The weather has been fair so no HVAC usage at all. This includes all power being pulled from my CharePoint Home. So it would include any preconditioning that I have been refraining from.
I think the EV range is about as accurate as it can be. It's pretty obvious the previous drive is one of the factors in the equation. Another is battery temperature and likely ambient temperature. In general I think I am getting a bit more range than the EV estimate while my wife gets a little less. I'm easier on accelerating from a stop than she is. It makes a difference. I think the battery gauge is also fairly accurate but some would disagree.
Not 100% certain yet it seems relatively accurate. It definitely takes into account your driving. If I hopped on the highway it would be way off not sure what it would do/look like on the way down.
Yes it’s been extremely nice. Although when I did have to use the heat is was hardcore bad news on range. I need to go back and look at my spreadsheet but it may be cheaper to run in hv mode if I need to use a bunch of heat.
When I used a bunch of heat it was 4.2 cents per mile. When I ran on the interstate in HV mode it was 4.8 cents per mile.
Wow!! You are now the undisputed king of EV mileage. Do you actually get the full 72 miles before hitting 0 and going into HV mode?
I don’t ever need to push it that far. Farthest I’ve gone on one charge is 48 miles so far and still had a bit of charge left.
Since the temps warmed up, am averaging 47-49 on EV with mostly 60-65 mph. Am driving normally (no extra effort), using the cruise alot and no heat and very little A/C.
Am curious to see what summer A/C will do to these numbers.
I'm still waiting to see 47. The weather has been in the 60's the past few days and I had 41 this morning. My commute to work is 5 miles at highway speeds, so I wonder if I will ever see high 40's.
Is that 41 EV mile range estimate, or did you drive until the battery was depleted at 41 miles driven?
The reason I ask is today when we got in the car it showed 42 miles EV range estimated. Then we drove about 15 miles and had 31 miles EV range estimated at the end of the drive. So that means we had at least 46 miles of electric range. The battery gauge showed only about 1/4 used. So the initial estimate was adjusted as we took that little trip.
I was showing 41 first thing yesterday morning after a full charge. I did not charge yesterday, and was showing 29 this morning. That agrees with the approximately 12 miles I drove yesterday. My question was if most of my driving history is at highway speeds, will the range calculation at full charge ever exceed 47? My expectation is that the miles/KwH for EV cars varies with speed much more than MPG with ICE vehicles. Driving slowly with minimal HVAC should use very little electricity.
